so whats the stock cams powerband??
ah.... well its a pretty sudden gain in power....
so a big enough cam will make the low end pretty doggy then???
always while on the topic of cams.... how exactly does duration affect the powerband??? like say a cam makes power from 3000-6000, it will be slower down low but by 3000 rpm the motor is pulling enough air to actually use all that time the valves are open to fill the cyls nicely???
and the bigger the duration the bigger the lope due to instability of the motor, the motor is actually trying to die right??(or would rather like to die) like the 3000-6000 rpm will idle at 800, at 800 rpm the motor doesnt pull much air and the cyls dont fill with air as good so thats where to lope comes from right???
More duration will hurt your low end and you will be required to by more stuff to make the new cam compatible. Leave the cam alone! and follow the advice on these forums for stock cam performance setups. I lost some low end below 2800 rpm's and 5 mpg when I switched to the e-cam over from stock cam 1.72 Rollers. I noticed much more midrange and power over over 5000 rpm's with the new cam. A cam change is DEFINETLY not cost effective in most cases!... and I did mine myself.
Your Bcam will sound great and run softer than the stock cam..you have to give up some power if your going to run that cam with stock heads and intake..but it will sound nice..provided the computer doesn't throw a hissy fit and not adapt, some cars will do that.
I wouldnt say softer then stock cam , mob recently went to the track with stock heads , intake and b cam and did quite well. I agree there will be less in the lower rpms but when your going down the 1/4 mile your revs are always pretty high so my bet is B cam runs down a stocker :)
Well everyone has their own opinion and that's the best part of this hobby..I have a HUGE appreciation for the stock cam. I loved the power curve on the street..F cam and B cam cars I have been in with stock intake and heads have left me glad I was running my stock cam.
Friend of mine had a bone stock car with just an H-pipe and went 13.9... I had a stock motor with a B cam, and can say the car was much slower than my dads stock 5.0 at the time!
Powerband is limited by the cylinder heads installed and ht eengien configuration. With the factory heads you're good for idle to about 4800rpm. The OEM heads and intake are very restrictive. With AFR165 heads I've see published dyno runs where the range on the stock cam was from idle to 6200rpm. That engine was carbed. It was in Car Craft magazine. You can see the article at http://www.carcraft.com/techarticles/116_0307_ford/index.html
i have always planned a cam swap, i am rebuilding so i think doing it while its easy will be best... also i think i sam going to save up money for a while and get some good heads like gt40s or thumpers, maybe even afrs or something if i get the cash....
i got a good deal on the cam also so i couldnt pass it up.
my 3.90s should help out with the low end that i lose from the cam..
my friend has a cammed mustang, he has stock heads and intake. lots of piddly ****. But his car was fast, just the low end lacked. But he got 373s in and man its pretty stout now....
I am pretty sure that test was done with AFR 185 heads. Nonetheless, it was very impressive. And that was a "later" stock cam (a little milder ramps than early ones.
From the article...
"..we made three changes in two steps: first, we bolted on a set of Air Flow Research's 50-state-legal 165cc aluminum cylinder heads."
As for the cam they used I found this in an earlier article "We were surprised to find how big the stock 5.0L cam was, measuring 208/212 degrees at 0.050-inch lift, with 0.445/0.445-inch lift at the valve with the stock 1.6:1 stamped rockers." I am not 100% it's the same engine, but I am 99% sure it is. Here's the link to that article... http://carcraft.com/techarticles/116_0111_build/
rsw007 said:
real street class runs the stock cam and a single power adder and they are getting close to the 8's in the 1/4 mile. so the stock cam is better than people give credit.
Those guys are running stock "spec" cams. Very precise custom made within the guidelines cams. Some organizations allow centerlines and lifts to be toyed with, but stock durations must be maintained. Other say "this" is the max lift, duration, lobe sep, etc... you can have.
But you are correct. The OEM cam is not given enough credit for what it is capable of.
