I reconnected my battery cables after they had been off for a while. I noticed that the negative cable was getting hot. I tested my cables with a multitool and found continuity across the negative and positive cables. Then tested positive cable with a common ground and found same.
I then disconnected all cables and wires from solenoid and checked each one against a common ground. I found that the 10 gauge yellow wire had continuity with the common ground. This wire is made up of three seperate wires, so I seperated them and found that the black and orange wire had continuity with the ground.
This black and orange wire feeds the #4 fuse. The #4 fuse controls the tail lights, side markers, instrument cluster, parking lights, and license plate lights. I've traced this black and orange wire the best I can through the engine compartment and under the dash. I cannot find anywhere that looks damaged. The wiring was still in the original loom.
What am I missing here? Electrical is not my strong point, but I'm not sure where to go. This wire is not supposed to have ground is it?! Is there another connection that I am missing somewhere?
Any and all help is appreciated. You can see the yellow wire in the upper, left hand side of this diagram that I robbed from Jrichker.
Thanks in advance!
Joe
Car is listed in sig....
Thanks in advance!
Joe
