Not trying to revive the flame-fest that the other thread had degraded to,
but since there was some inaccurate info posted there...
The '03 mach & the '01 Cobra have basically the same shortblock, with the exception of a slight compression increase from 9.85:1 to 10:1.
They both have the same forged steel crankshafts, weak cast powder connecting rods & Hyper-u-craptic pistons.
Both the Mach 1 & the '01 Cobra are equally as weak (or as strong) when boost is concerned.
Hand-built, yes. Better internals? Nope...
Not true at all.
Look at this dyno graph comparing my stock '01 Cobra to my stock '03 Mach 1 & tell me where all this extra Cobra top-end or mid-range power is:
The only thing hand-built about the '01 Cobra was the engine - the rest of the car goes down the regular assembly line, just like the V6/GT/Mach 1 cars...
Bottom line - both are great cars & should be respected for what they offer, no matter which one you choose.
GS4LEX said:I read in MMandFF mag that the MACH has really weak pistons and rods, where as the 99/01 cobra has a strong crank and better internals. So wouldn't the cobra be much better if u plan on adding boost or juice?
STUD said:I don't care if the stock mach1 is a hare faster in the straight line, the MUSTANG COBRA engine is HAND BUILT with a forged crank, and better internals.
STUD said:The mach's fall in power after 5k. My cobra makes 25 more hp between 5k and 65k, than the mach1 stock. The MACH 1 may have a little more power down low, but both cars fully modded(bolt-ons), the 99-01 cobra will pull on it after 5500rpm.
Not true at all.
STUD said:The bottom line, Mach's are assembly line cars, with assembly line motors and body's. The COBRA'S are HAND built by specially trained SVT techs on ROMEO'S NICHE LINE at the DEARBORN assembly plant.
credibility=GONE.
