RealQuick said:From what I have seen, the mach1 and 01 cobra have similar powerbands, but the mach just makes more rwhp/rwtq stock.
STUD said:Angus, regarding the HP difference at 5k rpm-6500 rpm. I was referring to my bolt-on modded cobra. My dyno sheet shows 25 more hp between 5000 rpm and 6500 rpm than a stock mach 1. Also, I know someone with a mach1 and all the bolt-ons, he maxed at 295rwhp with the same mods that I recorded 311rwhp. Same dyno.
STUD said:I don't know, maybe the 99-01 cobra's have more potential with mods than the mach's do.
Nazman said:01 Cobra vs. 0X Mach 1 vs. 99 Cobra:
Mach vs. 01 Cobra
99 Cobra
According to the dyno the Mach is making about 215RWHP @ 7000RPMs and according to my AFTER FIX sheet the 99 Cobra is making about 250RWHP @ 7000RPMs.....the Mach makes peak HP o/a 5000RPMs and the 99 Cobra makes peak o/a 6200RPMs....the Mach is making o/a 250RWHP from 4300+RPMs to 6500RPMs and the 99 Cobra is making 250RWHP from o/a 4300+RPMs to 7000RPMs....the Mach is making o/a 275RWTQ from 3300+RPMs to o/a 5300RPMs and the 99 Cobra is making 275RWTQ from o/a 3600RPMs to 5400RPMs.....so on my book...with equal gears....lets say Mach type 3.55 and equal axles let's say Mach solid...IMHO the 99 Cobra (for example) will kill the Mach....![]()
Just my .02
Naz
WE'RE glad you're done, and don't come back. Guys like you give all mustang owners a bad name. Your posts are nothing short of rediculous.SVOKING said:Ok, Guys.....
I'm done. Cya later
Angus, you should of kept the cobra. I don't have all the bolt-ons(no porting,no headers,no inner fender cai) 311rwhp, 305rwt. I doubt you'll come anywhere close to 325rwhp with those bolt-ons, maybe 300rwhp. You should of bought a 03 cobra monster, why settle for a mach 1. Mach 1's are great performance automobiles, but the 03 cobra with mod's crushes it.Angus said:Well, if you're going to compare a modded '01 engine to a stock '03 4V I wouldn't exactly call that "Apples-to-Apples".
As far as the Mach 1 you mention with "All the bolt-ons" hitting only 295 rwhp, I'd like to see that since my car made only ~ 8 rwhp less with only a drop-in K&N filter in the stock box.
With just the K&N, my Mach also made an additional 8 lb ft of rwtq (312 rwtq vs 304 rwtq) more than my full bolt-on (JBA 1 5/8" headers/Magnaflow X-pipe/Magnaflow Cat-back/C&L MAF/K&N Big filter/Steeda u/d pullies/Custom tuned-ECU/etc...) '01 4V did.
My '01 had 318 rwhp/304 rwtq when I had it custom tuned, and that was all that I could squeeze out of it with all the bolt-ons available.
Since my last dyno, I've added:
Bassani '03 Cobra catted X-pipe
Magnaflow Catback
K&N Aircharger intake kit
I'm going to dyno again in a week or so & I'll post how the modded Mach 4V compares to the modded '01 4V.
I'll overlay the graphs like I did in the previous post so we can all see how they truly compare.
If I was a betting man, I'd wager that my Mach will make ~ 325 rwhp & ~ 340 rwtq after receiving a dyno tune like my '01...![]()
I'LL GIVE YOU MY 99 cobra numbers. This car has bolt-ons, and no headers, no porting, no inner fender cai. 311RWHP, 305RWT. Here is my car compared to Mach1. Mach@ 4000rpm is 225rwhp, cobra is 225rwhp; mach@4500rpm is 260rwhp, cobra is 260rwhp; mach@5000rpm is 280rwhp, cobra is 297rwhp;mach@5500rpm is 275rwhp, cobra is 301rwhp; mach@6000rpm is 275rwhp, cobra is 311@ 6200rpm; mach is 250rwhp@ 6500rpm, cobra is 300; mach is 200rwhp@ 7000rpm, cobra is 275. I've gotcha by 17rwhp@5000rpm, 26rwhp@5500rpm, 36rwhp@6000rpm, 50rwhp@6500rpm,75rwhp@7000rpm. With porting, headers, and WMS cai I'd probably peek @ 325rwhp. But my numbers would go up throughout the powerband. Cobra's really wake up with mod's, especially in the upper rpm's. I have yet to see a modded mach 1 make 300rwhp.RealQuick said:Before 6800rpm the Mach1 makes more power/torque the whole way! The blue curve is higher than the red curve!!!!!!! Your looking at a little spike at the end. Area under the curve is the most important. Mach1 wins flatout.
STUD said:I have yet to see a modded mach 1 make 300rwhp.
STUD said:With my 4:10 gears and good tires, I think I'd smoke ya even with the IRS.
STUD said:I'm working at getting the dyno sheet posted, so you can see for yourselves.
