Some final wire hiding q's.
Ok, if i dont install my long tubes this weekend, im going to hide wires instead. how do you guys fit the wires in the fender w/o lengthening the wire? i guess you totally remove the harness of all tape and sleeving? this is the only thing that worries me.
fox racer,
first unplug all of plugs on the main harnesses.next what i had to do to make the wires properly reach inside the fender was,like you said, remove all of the tape from the wiring harness,i used a razor(be careful).next to get the wires into the fender through the rear of the strut you must either enlarge the holes or cut the wires then solder them together inside the fender etc. etc. this is just a summary i would give you a complete description but i dont know if you already know all this. if you need more info just ask or do a search.im sure almoststock will help you as he is the one that has helped me. dont be worried about taking the tape off the wires. it is a little discouraging seeing a ****load of exposed wires, but once you get started youll see it isn't that hard.good luck!
fox racer said:
ALMOST STOCK... i have seen your site, but that link you posted, thats wat i needed! looks like im doin it this weekend now. the site helped, but that link is wat im using. thanks amillion man! thanks you too will!
I'm glady was able to help.
Remember think about where you're going at least twice before you make a move, and you'll find out it's not nearly as hard to do as you thought.
The passenger side is your easiest side, I'd start there first if it were me that way you get a good feel for what you need to do.
