Some help needed with wheel fitment/offset
im4darush
25
I have a 92 coupe with a full SN95 5 lug, as well as 4 wheel disc conversion. Am looking at a set of 17X9 bullitt wheels with 24mm offset and need to know if this will work. Can anyone help me out?
With 94-98 shafts a 17x9 with a +24mm offset will still sit inside the wheel well. They will be right at the edge with a 275. I'd run a Nitto since they run small that way you'll have the most clearance. IF you get Summitomo 275's they will have less clearance since they run wide.
Your best bet for clearance and overall look is a +45mm offset 17x9 wheel.
Not really a wheel type of pic, but this is all I got right now. This is a 97 axle with 17X9 +24mm and a 275 Summi. I'm going Nitto 275 once this beast is done.
And yes, the right side sits up higher than the left, and I don't know why. It pisses me off. Next year this things is getting brand new springs.
Just found out that the car has..
Motorsport 31 Spline Axles
Ford Explorer 31 Spline Carrier
Does this tell us anything about the length of the axles?
Not really. We now know that your car has 31 splines axles which is great, but Moser makes axles in any spline/length/lug combo you need. It's best to just borrow some wheels and see how they look if you don't wanna pull the shafts out.
Ok, just got more info from the prev owner. Seems I was incorrect!! The car has the M-2300-K - Ford Racing 5-Lug Cobra Brake Conversion Kit installed.
But I guess that still does not help with the axle lengths.
