Some help with compression figuring
  • Thread starter Thread starter 90_Red_LX
  • Start date Start date Aug 4, 2007
90_Red_LX
668
Asheboro, NC
Aug 4, 2007
  • Aug 4, 2007
I believe I have the wrong pistons. I wanted 10.5-11:1 comp but I got probe flat tops, which is well below what I wanted from what I am figuring.
Motor is a 306. Here is the link to the probe site with info about the piston. It's the top set. 4.030 bore. Gasket is .045 from what I got from the ROL catalog compressed.
http://www.probeindustries.com/Pistons/Pistons_SRS/Ford/Ford_302.htm
What do you guys think?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Aug 4, 2007
  • Aug 4, 2007
So your looking at the 10682-030 pistons? That is the kind I have...
You can definetly get a piston that allows more compression and actually give you some power...
You could also try the ROL Headgasket - HG32841HR which is a .039 compressed thickness. Those are the gaskets I run from Ed as well...
He told me that he saves the .045 for supercharged applications...
You could try the 10466-030 piston...about 11.3:1 with 58cc heads...but with some head chamber work (money though), you could run the high 10's...
None-the-less, a bump for ya bud
Edit: With running the higher compression like that, you may want to think about getting a new cam from Ed designed for the increased static compression.
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine Raising compression on a relatively stock 302
  • keel
  • Jul 9, 2023
9K
Fox 5.0 Mustang Tech Jul 20, 2023
keel
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
Fuel 19lbs EV6 fuel injectors, what fuel pressure???
  • PonyGTrider
  • Jul 11, 2024
  • 6 7 8
13K
Fox 5.0 Mustang Tech Jul 25, 2024
PonyGTrider
