some questions on new engine!
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Heya guys got some questions....
My car smells rich and sorta has that raw gas smell to it at idle. when it is loping, when i am driving it is fine and dandy. Smells rich at idle only. is this normal with the cam??
also when cruising in say 4th gear or something at low rpms like 1000, the car will start bucking back and forth. this normal. anything above say 12-1300 it runs fine.
i also need to know if i should stick with my stock 19lb injectors or if i would benefit from some 24lbs. I plan on a power adder sometime, SC probably, or nitrous, i know i would need them then, but would it hurt my car to go ahead a get the 24lbs and a nice Massair now?
Mine bucks at low rpm in too high of a gear....and you should be fine with the 19 lb's ..as for the rich smell at idle I would think that may need some looking into but I can't help you there....How much difference did you notice with this new engine
Stick with the 19s for now They are plenty for your combo. I am still running my 19s with the combo in my sig.
Most cars will buck some when you are at that low of an RPM in a higher gear, my 91 5 speed did it. Just down shift and get the RPM up some
My 93 runs rich after my cam swap but I am just too lazy to look into it too much. Besides mine isn't a DD only a weekend driver.
If you have an OR-X or OR-H pipe you will smell the exhaust gas at idle.
As far as the bucking is concerned, welcome to alphabet cams. A new Mass Air might help a little but most likely it will be something you will have to live with.
I know a few tuners who can tune it out but most are interested in max power only and do not try to tune for drivability.
Also you may want to try adjusting you fuel pressure a little, it sometimes helps as well.
i noticed a HUGE difference!
the car throws u in the seat more and gets up alot faster than it did b4
