  • 1994 - 1995 Specific Tech
some suspension questions
  • Thread starter Thread starter 90bronconate
  • Start date Start date Sep 27, 2005
9
90bronconate
124
Phoenix, AZ
Sep 27, 2005
  • Sep 27, 2005
ok so i'm planning to do my suspension throughout the year and i have some questions that i couldn't find by searching.
heres' what i'm planning on doing eventually with the suspension
front coil over kit
strange 10 ways front and back.
upper/lower control arms
c/c plates, bump steer kit and stuff
i mainly care about accelerating in a straight line, but i don't want it to handle worse than stock (stock handling is adequate for me) and i'd like it to be lowered as well. from what i've read stiffer is better for the back and softer is better for the front at the strip right? so i was thinking that if i got the front coil overs with soft springs and 10 ways, they would take care of both worlds right? i could raise the height and soften the struts for the drag strip, then lower it and stiffen the struts for the street.
and what about the back springs? could i use the stock springs and cut them to the height i want or should i try and find a stiffer lowering spring?
sorry for the long post, just trying to get a game plan together.
9
90bronconate
124
Phoenix, AZ
Sep 28, 2005
  • Sep 28, 2005
ttt
95COBRA241
339
Delray Beach, FL
Sep 28, 2005
  • Sep 28, 2005
I am not to familiar with the front coil over set up, but from what I hear guys love 'em. As for the rears, get a good set of lowering springs. Cutting a coil is not a good or safe idea for the stock springs.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Sep 28, 2005
  • Sep 28, 2005
Im still kinda searching this myself (and doing as I go along). If youre plannning on Coilovers, then you need the 4-bolt C/C plates. Steeda has them, and I just got the chrome ones from MM. From my recent posts, it seems Bilsteins are the way to go for front struts, and they have coilovers to go with them.
As far as control arms...IM still undecided myself, but Ive ruled out Granatelli. Im looking at these ones from UMI on Ebay. Steeda has them for $179 (LCA) and UPR has them. They say the cheap ones are "cheap" but those who I see with them havent really complained. If my stock ones are still good after 10 years, how bad could the "cheap' ones really be.??
Dont forget if you are upgrading suspension to get some full lenght sub frame connectors and have them welded in.
So far, I have Steeda Springs and SFC, 4-bolt c/c plates going in, and that's about it. I havent decided if my next move is LCA or Bilstein Struts.
Good Luck
RC
9
90bronconate
124
Phoenix, AZ
Sep 28, 2005
  • Sep 28, 2005
yeah. i wasn't specific on the parts, sorry.
i'm plan on the pro3 control arms, mm 4 bolt c/c plates, and mm full length sub frames. so that's pretty much covered.
what about the upper control arms? should i get the adjustable uppers? because when i lower it, won't the pinion angle be off? or is it not really an issue?
oh, and am i right about the stiffer springs in back and softer springs in front?
94GTLaserRC
11,178
Sep 29, 2005
  • Sep 29, 2005
Im waiting for an answer myself on this one, b/c a lot of us run lowered cars with stock UCA.
RC
9
90bronconate
124
Phoenix, AZ
Sep 29, 2005
  • Sep 29, 2005
so can anyone tell me if the adjustable uppers are necessarry if i lower the back 2"?
and also am i understanding the physics right? stiff back and soft front for drag?
94GTLaserRC
11,178
Sep 30, 2005
  • Sep 30, 2005
Curious as well, and free bump.
RC
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
