someone just explain the importance of these basic mods?
nicholasm617
so ive just come up with an 86 capri 5.0 in good shape, my first v8 (thankfully) so i wanna do stuff to it. whats the big deal about gt40 heads and explorer intakes? what kind of improvements can i actually notice from stock? (ive spent an hour searching and didnt see any answers # wise. i get the feeling its common knowledge i dont have yet.
  • Sponsors(?)
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,435
2,868
234
74
Dublin GA
lowendmac.com
The GT 40 heads and explorer intakes out flow and out perform the stock Mustang equipment. The relative plentifulness and cheap prices in junkyards makes them an inexpensive upgrade to an otherwise stock engine. The 1995-2000 V8 Ford Explorers and Mercury Mountaineers are found in a lot of different junkyards and the prices for parts is reasonable in most cases. GT40 heads and Explorer intake manifold are probably worth 30-40HP when combined. The heads will need new valve springs and a valve job if you hope to get this kind of HP improvement. What you actually get depends on having a larger MAF & throttle body and basic good engine health to take advantage of the improved breathing capacity.
On a budget? do the junkyard upgrade...
Gears - 87-88 T-Bird Turbo Coupe rear axle - disc brakes and 3.55 or 3.73 gears in one package for $125-$300. Add another $100-$200 or so to complete the brake upgrade.
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1 *2
95-97 Ford Explorer intake manifold & throttle body $150-$300. The intake manifold flows 220 CFM +, much better than stock. Throttle body is 65 MM, bigger than the 60 MM on stock stangs. I got a 96 with EGR passages that match the stock setup, so my smog gear works just like factory. You’ll need a 65 MM EGR spacer & new gaskets for $65-$90 so you have a place to mount the EGR & throttle linkage.
3G alternator from 94-95 Mustangs or other Ford. $20-$120. A must have to make the electrical system work like it should or if you have an electric fan. You’ll need a 4 gauge power wire and a 125-135 amp fuse to go with it about $15- $30.
Lincoln MK VIII electric fan -$40-$160. Free up some HP by not having to drive the stock fan. The 3G alternator upgrade is a must have prerequisite before you do the MK VIII fan. You won’t have enough electrical power if you don’t do the 3G upgrade.
Aluminum driveshaft: (courtesy of shawn13) It needs to be from a 92-93-94 Aerostar AWD. It measures 45 ½” center of the front U-joint to center of the rear U-joint. You will need the U-joint, part #PUJ353 from NAPA. The Canadian NAPA pat number is 1-0134BF. It should bolt right up after the U-joint swap.
Note: This driveshaft is not an exact duplicate of the Ford Racing part. It is 3” in diameter while the Ford Racing part is 3.5” in diameter.
Use a piece of string and wrap it around the driveshaft. Make a mark on the string where the ends overlap.
Measure the length of the string:
On the 3" AeroStar driveshaft the string will be 9.42" or about 9 7/16" long.
On the Ford Racing 3.5" driveshaft the string will be 10.99" or about 11" long
*1.) Metal flange adapter Ford MAF Adapters - Air Filters - Kurtz Kustomz Motorsports, Inc. KKM Buy the TR70 for $40. Or spend some time on eBay looking for one that may fit.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
Evidently the –A1A, -A2A, AA, etc. on the end of the part number is a minor variant that did not change the operating specs. You should be able to ignore it and have everything work good.
cammed89lx
87
afr's are a buttload but you really cant beat the performance. By the time you get them, and have them on the car you wont be disappointed. They are one of the highest quality heads available.
Kdubslugga
1,515
37
Akron, OH
Visit site
Nobody has mentioned it so I figured i would say it. There is a difference between gt40 and gt40P heads. Gt40Ps come off all the Explorers and Mountaineers, while the gt40's which are slightly better are off the 93 Cobra
No.11
614
Los Angeles
^ pre 97 explorers also have the gt40, with the 97+ having gt40p. and... most would argue that gt40ps are actually better. however I have yet to see a real conclusion as to which is best.
Maryland Stang
1,656
27
39
62
Greenville, NC
Your best bet is to find a set of Ps that someone else put money into. I got mine with Manley 1.94/1.60 valves already in them. I sent them to the shop and had them ported and shaved. For about $750 I have a really nice set of heads.
FastDriver
My dad had a bra
Sep 5, 2001
4,543
1,248
214
Fort Knox, KY
Don't mean to sound arrogant, but I really don't see the point in doing all that work on a car to put on a set of heads that are only going to pick up 30-40 hp. Then again, I'm fortunate to have the money to afford the nicer stuff. So, I'm not knocking those who choose to go that route for financial reasons.
In any event, 93 mustang cobra had GT40 heads, and essentially equivalent Cobra intakes and they made 225-235 rwhp as compared to stock 5.0s that made 190-200 rwhp through manual trannies. Keep in mind that the Cobra had some other parts that helped out too and a cam that hurt a little. I think that without any other significant changes, you should see 30-40hp as already stated earlier in this thread.
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Go on eBay and look up Odessa cylinder head.. Gt40p heads delivered to my door for 370 about a year ago.. No core charge if you buy them on eBay. Remanufactured, new valves 1.54 exhaust valves instead of 1.46 I think.. They were clean and ready to install with new springs.. I added 1.7 roller rockers with the stock cam.. Runs good no clearance issues..
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,307
9,421
224
Massachusetts
I have always been under the impression that the GT40P's without the internal EGR flowed better.
Not necessarily flow, but the revised plug location gives a better flame front to the incoming fuel charger resulting in "better" overall combustion. I've always felt the gt-40P were superior to gt-40. The "p" is for performance
LarsD
2,685
117
123
Texas
Visit site
That's it, I forgot about that too.
Maryland Stang
1,656
27
39
62
Greenville, NC
Exactly. Going with aluminum aftermarket heads usually involves a whole lot more cost than a lot of people realize. A set of decent aluminum heads is going to set you back at least $1200 shipped. You may also need a set of bolt spacers, ARP bolts, pushrods, rocker arms and a fancy intake to match the fancy heads. Before you know it you've spent $3,000.
You can bolt GT40Ps on the way they are. If you're not particular you can use the original pushrods and rocker arms. Or you can go all out and get a Explorer intake, B or E cam and some FMS 1.7 rockers and have it done for half the cost of the aluminum heads.
v8stang289
Well-Known Member
Apr 22, 2008
107
92
59
Something else you have to worry about with an 86 5.0 is piston to valve clearance when running anything other than stock E6 heads. The flat top pistons in the 86 motors limit what you can run, so always check to be sure there is adequate clearance.
Thread starter Similar threads Forum Replies Date
derek2079 Could someone explain how to make my windshield nozzles spray on my 67? 1965 - 1973 Classic Mustangs -General/Talk- 2
C Can Someone Explain In Layman Terms These Obdii Codes? SN95 V6 Mustang Tech 3
9 Fuel leak? Can someone explain an efi fuel tank to me? Fox 5.0 Mustang Tech 2
Stumbaugh PTVC question. Someone please try and explain SN95 4.6L Mustang Tech 2
KillaKev702 Can someone explain altitude change to me? 1996 - 2004 SN95 Mustang -General/Talk- 13
9 can someone explain runner volume plz 1994 - 1995 Specific Tech 20
R Can someone explain/verify this for me? 2005 - 2009 Specific Tech 15
BK_CAULEY can someone explain the advantage of coil overs? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
spirockp Can someone explain my 1/4 times to me in English? Classic Mustang Specific Tech 16
Mustang5L5 Can someone explain the hydroboost setup for me? SN95 4.6L Mustang Tech 0
Boostedpimp someone please explain the difference between "draw-thru" and "blow-thru" meters Fox 5.0 Mustang Tech 5
deftsound Someone please explain this to me SN95 4.6L Mustang Tech 14
Cruizer67 Can someone explain? Classic Mustang Specific Tech 6
1987Rock I know the main differences, but can someone explain..... 1996 - 2004 SN95 Mustang -General/Talk- 18
2Tone5.0 Can someone explain this? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
N Can someone explain to me about an aftercooler? Fox 5.0 Mustang Tech 5
oz Can someone explain 'Drifting' to me? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 25
hotstang_46 can someone explain 87-93 strut, not same old?'s SN95 4.6L Mustang Tech 9
kingc Someone please explain this to me 1996 - 2004 SN95 Mustang -General/Talk- 7
carbed87 Blowby, can someone explain... Fox 5.0 Mustang Tech 22
95Vert Can someone explain the whole higher octane gas is not better thing? 1994 - 1995 Specific Tech 19
P Can someone please explain how Ford/SVT just keeps ****ing up? 1996 - 2004 SN95 Mustang -General/Talk- 21
Foxfan88 firewall adjuster... can someone explain?? Fox 5.0 Mustang Tech 9
InMyPrimeSVT Can someone explain to me LCAs? Fox 5.0 Mustang Tech 15
L Someone explain to a Brit about Trick or Treat... 1965 - 1973 Classic Mustangs -General/Talk- 21
chobracobra Someone explain timing to me Fox 5.0 Mustang Tech 19
W Can someone explain this to me? Fox 5.0 Mustang Tech 9
G Can someone explain to me what's wrong? (Clutch) 1974 - 1978 Mustang II Talk & Tech 2
darthcual TPS can someone explain what i'm looking at Fox 5.0 Mustang Tech 15
hersheyman Could someone explain the difference in gear sizes? SN95 4.6L Mustang Tech 4
S Can Someone Please Explain A Pushrod Engine. SN95 4.6L Mustang Tech 18
R Can someone explain this car to me Classic Mustang Specific Tech 11
1105 can someone explain this to me... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
N8Miller Can someone explain to me a Lightning MAF on a fox body? Fox 5.0 Mustang Tech 4
Jekyl Supercharger noob. Someone please explain.. Fox 5.0 Mustang Tech 2
Must-Be-A-Stang Can someone explain.... Fox 5.0 Mustang Tech 31
OrangeMustangGt Can someone explain runner length on intakes? 1994 - 1995 Specific Tech 2
D Can someone explain to me suspension? Fox 5.0 Mustang Tech 7
S Can someone please explain Classic Mustang Specific Tech 1
Kdubslugga Can Someone Explain Lower Control Arms for me? How do they work? Fox 5.0 Mustang Tech 3
S Can someone explain why this happens????? 1994 - 1995 Specific Tech 8
MustangMatt1966 Can someone please explain these specs on my camshaft? Classic Mustang Specific Tech 8
1 Can someone explain to me how my car is still alive after 2-->1 shift??? SN95 4.6L Mustang Tech 27
M PLEASE SOMEONE EXPLAIN... Fox 5.0 Mustang Tech 1
M Someone please explain pinion angle adjust. Fox 5.0 Mustang Tech 4
R Can someone PLEASE explain.... Classic Mustang Specific Tech 8
9 Someone Explain FMU Hookup For Me Fox 5.0 Mustang Tech 3
washMO66 Can someone explain the power valve Classic Mustang Specific Tech 14
none67 can someone explain this to me.. Classic Mustang Specific Tech 5
D Someone please explain this!!!1 Fox 5.0 Mustang Tech 5
