  • 1994 - 1995 Specific Tech
Someone please help me!!
  • Thread starter Thread starter AznStanger3v
  • Start date Start date May 1, 2004
AznStanger3v
2,026
Northern VA
May 1, 2004
  • May 1, 2004
Ok guys, I went to the track last thursday. Everything on my car was doing good. I have a DVD Player with a 7 inch screen in my dash. The DVD takes the bottom "slot", and i put the screen in the top "slot". So as i line up, i turn everything off. I run 3 runs and as im leaving, i try to turn the dvd player on but it wont come on. I re-wired it, nothing. Check every single fuse, everything is good. So i think i messed up the dvd player, so i use my friend alpine head unit and put it in my car. it doesnt turn on. i thought he messed his up. i bought a new harnass and used my friends pioneer head unit, nothing. Now, apparently my car is completey messed up. How the hell do i fix this? what is wrong? Its driving me nutts!!!
R
robertdale
382
kentucky
May 1, 2004
  • May 1, 2004
sounds like a blown fuse... You need to run a hot wire from the battery to test with you may have pinched the power wire into.
85GTlover
704
  • May 1, 2004
I agree, check the other stereos with another power source so you know there all good. It has to be line,fuse or deck you would figure.
saxman9801
241
Boise Idaho
May 1, 2004
  • May 1, 2004
Ok first off did you check all the fuses in both locations under hood and under dash? also did you use the a wire harness to hook up your deck or did you just chop the harness off? If you used a harness make sure one of the pins did not push it's self out so it is not making contact, also if you look down to the right in the opening where the cd player would go there are two more harnesses down there stuck to the side of the panel there, one is a black rectangular one and the other is a grey rectangular one, these must be plugged in it is possibile one came loose, and also check your ground and make sure it is getting a good ground, the system will not operate with out a good ground connection, good luck let me know if you need more help dan
AznStanger3v
2,026
Northern VA
May 1, 2004
  • May 1, 2004
a. I did check both fuse boxes
b. Ill check every harnass
c. what do you mean the side harnasses are "plugged in". I see them there against the side. they are both the female haranasses.
d. where should the ground be? i know its the black wire, but where does it lead to?
AznStanger3v
2,026
Northern VA
May 1, 2004
  • May 1, 2004
son of a bitch! im over here trying to fix my problem and what happens??? now my dome light, clock, and glove compartment lights wont come on! I haaaaaaaaaaaaaaaaaaaaate Ford soooo much right now! I replaced every single fuse and they are all good now. I just want to kill!!!!
stack
174
Rochester,NY
May 1, 2004
  • May 1, 2004
Get a multimeter and see if you have 12volts DC between the yellow wire and ground. Make sure that the radio is grounded via the black wire. Then turn on the key and see if you have 12 volts between the red wire and ground. If you get 12v on both the radio should work fine. Also if you have stuff hooked up to the remote turn on lead (blue wire from radio) make sure you have 12V on that lead to ground when the radio is turned on. The whole system is really simple just take a step back and rethink it.
stack
AznStanger3v
2,026
Northern VA
May 1, 2004
  • May 1, 2004
ahhh what a horrible day. in addition to my interior not lighting up, now the speedometer doesnt even work. i love this magic. and to top it off, i hate my girlfriend so much right now. shes such a bitch! why always me?! i hate her
R
robertdale
382
kentucky
May 2, 2004
  • May 2, 2004
how close are you to the KY border? Sounds like a bad ground or a power wire into. Need to lay in the floor of the car and look at the wireing to make sure everything is OK. Make sure there is no bare spots in the wires or any thing out of normal.
Edit... also check the fuses inside the engine compartment beside the battery as well as under the dash.
M
Please help me identify this.
  • MattyB77
  • Jul 2, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 4, 2026
gkomo
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
