I might be getting this car, it's a 1999 Black SVT Cobra... What HP range is this in?
MOTOR:
BUILT BY HOUSTON PERFORMANCE
NEW CRANK
NEW RODS
FORGED PISTONS
ARP BOLTS
PORTED AND POLISHED HEADS
CUSTOM GRIND "BLOWER" CAMS
5 ANGLE VALVE JOB
NEW SPRINGS
EXTRUDE HONED INTAKE
DRIVETRAIN:
T-56 6-SPEED TRANNY
STEEDA SHIFTER
RAM 900 CLUTCH
FIREWALL ADJUSTER
ALUMINUM DRIVESHAFT
BUILT SOLID REAR AXLE
4.10 GEARS
MOTORSPORT 31 SPLINE AXLES
EXHAUST:
HOOKER 3" CERAMIC COATED LONG TUBE HEADERS
3" CAT-BACK X PIPE
SUSPENSION:
(FRONT)
TUBULAR K MEMBER
TUBULAR A ARMS
COIL-OVERS
ILLUMINA 5 WAY ADJUSTABLE STRUTS
3-BOLT CAST/CAMBER PLATES
(REAR)
KONI ADJUSTABLE SHOCKS
H&R SPRINGS
STEEDA ALUMINUM UPPER AND LOWER CONTOL ARMS
POWER ADDER:
HOUSTON PERFORMANCE WET KIT
125 SHOT
BOTTLE HEATER
WIDE OPEN THROTTLE ACTIVATED SWITCH...
THIS HAS ONLY BEEN ON ONCE....LET ME REPEAT THAT.. THE NITROUS HAS ONLY BEEN USED ONCE FOR A TEST AND TUNE.
MISCELLANEOUS:
CUSTOM COMPUTER FOR N/A AND P/A APPLICATIONS
REAR SEAT DELETE
03 COBRA SHIFT KNOB
AUTOMETER EGT GAUGE
AUTOMETER NITROUS PRESSURE GAUGE
KUMHOS UP FRONT
NITTO 555R REAR
MOTOR:
NEW CRANK
NEW RODS
FORGED PISTONS
ARP BOLTS
5 ANGLE VALVE JOB
NEW SPRINGS
DRIVETRAIN:
T-56 6-SPEED TRANNY
STEEDA SHIFTER
RAM 900 CLUTCH
FIREWALL ADJUSTER
ALUMINUM DRIVESHAFT
4.10 GEARS
EXHAUST:
3" CAT-BACK X PIPE
SUSPENSION:
(FRONT)
TUBULAR K MEMBER
TUBULAR A ARMS
COIL-OVERS
(REAR)
H&R SPRINGS
POWER ADDER:
125 SHOT
BOTTLE HEATER
MISCELLANEOUS:
REAR SEAT DELETE
03 COBRA SHIFT KNOB
AUTOMETER EGT GAUGE
KUMHOS UP FRONT
NITTO 555R REAR
