sorry guys last camshaft question...
1973mach1
457
PA
Specifications:
* Advertised duration: 270 intake/270 exhaust
* Duration at .050 in. cam lift: 224 intake/224 exhaust
* Gross valve lift: .519 in. intake/.519 in. exhaust
* Lobe separation: 110 degrees
* RPM range: 1,800 to 5,800
* Mild rough
Is this too wild for the stock 351c 2v with stock springs and FMX tranny with stock stall?
Thanks,
Jim
I just looked up the stock spring specs on the 2bbl Cleveland and they're a little weak for that kind of cam, even when new, yours aren't I'm sure. Better upgrade your springs. Get a spark plug adapter to connect an air hose and a spring compressor and change the springs without pulling the heads. Do this AFTER the cam break-in though. Those old weak 2 bbl springs will be easier on the cam during break-in.
It's not a difficult or complicated job, even for a beginner. Go to your favorite local auto machinst and ask them to show you how to install the locks and retainers, so you'll at least know how to do it right. It'll take a couple extra hours at the longest to swap the springs in addition to the cam.
