Guys sorry..I also posted this on JeepsUnlimited.com, but I need to increase my chances of getting this figured out this weekend; i've been working on this stupid Jeep for about the last 8 weekends and i'm tired of it. I replaced intake gaskets on my 94 Grand Cherokee 5.2 L, put everything back and had a problem with a fuel leak at the rails, turns out i wasn't putting them back correctly. Got that figured out and the jeep will start and run, but if you give it gas, it revs and then dies and is hard to start again...but I keep cranking and it starts. It was having this problem before and was overheating to like 260*, so i replaced the thermostat, which then I broke a bolt off in the intake, which in turn led to replacing the intake gaskets when I had to pull the intake to get the bolt out. I've also replaced the water pump recently. I pulled the distributer to get the rotor off cause it was stuck (probably still on there from the factory), but I did mark it and thought I put it back where it was. Also, there's a steam coming from the motor, which could be gasket compounds burning off..i also threw some oil in the valve covers to lube it up a little. It is blowing smoke from the tail pipe in 50 degree weather, but my mom said that's just normal...otherwise it's got a head gasket leak. My question basically is...would it start and idle w/ the distributer off a little, but then die after giving it gas? It will rev, but then when I let off of the gas, it drops below idle RPM and dies and then it's hard to start again, but will after some cranking. My brother said maybe it's running rich causing it to die. Also, and this could be the problem, but I have one connector on the pass. side of the motor that I can't find the sensor for....it's in the wiring loom w/ the injectors, but I believe it's a female connector w/ 3 holes....anyone w/ a Grand Cherokee have an idea where this thing plugs in at? I'll looked at charts and i've looked all over for the connection. That could be the problem I guess, but i'm kinda doubting it.
I'll pull a plug tomorrow and see if it's soaked to see if it's maybe running rich, but other than that...
Seems like i'm right back at square one. Any ideas? If you need anymore info let me know. Please help ASAP.
