Interior and Upholstery Sound deadening fox interior questions
  • Thread starter Thread starter AnthonyA1234
  • Start date Start date Apr 17, 2024
First Prev 2 of 2
General karthief
Mod Dude
Aug 25, 2016
28,113
10,729
213
polk county florida
Aug 24, 2024
#21
  • Aug 24, 2024
  • #21
limp said:
Is the precut plastic liner LMR sells the one to use?
I imagine, have not looked around to compare to other sources.
2000xp8
SN Certified Technician
Aug 8, 2003
8,067
1,654
194
NJ
Aug 24, 2024
#22
  • Aug 24, 2024
  • #22
The LMR moisture barriers are definitely thicker than the originals.
I took a look at all the ones i have, which i'm glad i did, it sorta gives a map of what holes need to be kept during the kilmat install.
It also doesn't look like they get taped or stuck on to the door, more like there are push pin holes and they get mounted to the door panel instead.
Reactions: General karthief
90sickfox
Wasn't a pretty sight...and I've got big hands
Mar 2, 2015
6,952
5,831
213
Aug 24, 2024
#23
  • Aug 24, 2024
  • #23
I cut up 3 mil contractor bags to make door moisture barriers. Stuck on with butyl window weld. That stuff stays sticky. Works great. I buy them for the garage trash can.
2000xp8
Aug 8, 2003
8,067
1,654
194
NJ
Aug 25, 2024
#24
  • Aug 25, 2024
  • #24
I finished up my passenger side door yesterday. Behind the speaker an entire sheet of kilmat fit, so i just used a full sheet there and then surround the speaker inside the door as well as possible. Then i just used random strips on the door support and panel inside. Then the door itself, i install the kilmat on all the parts i though the panel could rattle up against the door itself. Nothing real special, i don't really see what covering the entire door would do.
I also decided to put the moisture barrier back on my Pside door. Honestly it was too easy not to. It doesn't really get mounted to the door panel, it get glued to the door itself.
At $23 a set i'm not sure i'd be making them myself. They are pretty solid and i can't see them tearing period, even if you had to pull it off.
The fit was pretty much perfect. Are they really necessary? Not sure, but it was really little to no hassle like flimsy originals, these keep their shape.
Edit: One thing i will add is that i bet the LMR moisture barrier helps prevent road noise from coming through all the large openings in the door since i covers pretty much the entire thing with few openings.
85GTStangGuy
5 Year Member
May 19, 2021
1,008
631
133
Jax, Florida
Aug 25, 2024
#25
  • Aug 25, 2024
  • #25
From the factory, the vapor barrier is actually affixed to the door, not the door panel, with ribbon sealer. Don't know Ford's exact stuff, but here's the 3M product I got...
Amazon.com
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,518
2,941
173
Florida
Aug 25, 2024
#26
  • Aug 25, 2024
  • #26
I guess you could tape up a piece and " poke or cut" wherever you need to for screws or cranks???
Reactions: 90sickfox and General karthief
limp
5 Year Member
Oct 4, 2020
5,518
2,941
173
Florida
Aug 25, 2024
#27
  • Aug 25, 2024
  • #27
My 83 has the " Kraft paper" which I was not going to use... I thought the plastic was a better option....
85GTStangGuy
5 Year Member
May 19, 2021
1,008
631
133
Jax, Florida
Aug 25, 2024
#28
  • Aug 25, 2024
  • #28
My '85 had the plastic barriers, but they are thin and not near as durable as the R.E.M. brand vapor barriers that I got at NPD. The ones at LMR may very well be the same part as the NPD ones, just sold under their 5.0Resto brand name.
Watershields, Door Trim, Plastic Style, (2) Incl Rh And Lh Side, Designed To Seal Out Moisture And Protect Door Panels, Adhere With 3m8509 Compound - #M-20126-1BK - National Parts Depot
Buy part #M-20126-1BK Watershields, Door Trim, Plastic Style, (2) Incl Rh And Lh Side, Designed To Seal Out Moisture And Protect Door Panels, Adhere With 3m8509 Compound for your classic 1981-1986 Mustang from National Parts Depot. Free shipping on orders over $300, fast delivery & everyday low...
www.npdlink.com
https://lmr.com/item/LRS-23704AA/87-93-Mustang-Door-Panel-Moisture-Vapor-Barrier
Reactions: General karthief and limp
First Prev 2 of 2
P
Fox 17" Deep Dish Bullitts on Rear of Fox, 275/40/17?
  • pindude80
  • May 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 4, 2025
J
Fox body - godzilla, coyote, or 408w stroker - Best route for budget build?
  • jaygee15
  • Jan 27, 2025
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 30, 2025
2000xp8
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
H
Drivetrain 4R70W clutch friction/metals/piston set up questions for transmission guru
  • Hizdudeness
  • Apr 4, 2024
Fox 5.0 Mustang Tech Nov 15, 2024
slow84lx
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
