Sounds like lifter tapping but...well
silveri
Hey,
I've a '92 Crown Vic with a 4.6 that has this constant tapping noise. It seems to be coming from the top end and two of my more mechanicly inclined friends agree. Since it's on the top end I don't think it's a rod so I would say it was a lifter the way it sounds but since a OHC engine like this doesn't apparently have lifters what could it be and how would I go about fixing it.
Just a side note it drives just fine with no hesitation or anything irregular and the oil pressure is fine. Thanks for your time.
silveri:
Get a mechanic's stethoscope (e.g.--Lisle, made in USA, about $10) and put the tip on each injector and then along the cylinder head right beside the spark plug hole. The injectors can be pretty loud. By listening to the cylinder head, you can tell pretty accurately where the noise is. A length of tubing will work somewhat, too, but not as well as a stethoscope. It's the only way to track the noise down.
