Spark Ping Related To Check Engine Light??
Jordan Warta
48
Recently bought a 1995 Mustang GT 5.0 with 165,000 miles. It has a spark knock in 3rd and 4th gear and under hard acceleration it gets worse. I tried sea foam in the gas tank and drove it to my school (4 hours away) and tried premium fuel. Did not work, any other suggestions? Does the spark knock damage the engine if not fixed over time? Also the check engine light started to come on for a few seconds under hard acceleration (can happen at 20 mph or 50 mph given that I floor it) this just started happening last week. Is this related to the spark knock?
View: https://www.youtube.com/watch?v=64_WImLxbvI
audio isn't the best but noise is second half of video
Called 3 auto part stores and Firestone none of them have OBD1 scanner for 1995 year cars. I'll call some more places when I get home in a few weeks and hopefully find one.
Sears.com
Amazon has it as well. Free shipping with Prime works out the same as this.
Basically if you have an OBD1 Mustang, you should own this tool.
And to answer your question, yes it is possible they are related, but you need to read the code to understand what the issue is
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus Digital Ford Code Reader (3145) Equus - Digital Ford Code Reader 3145.
It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
