Spec stage 3 users, adjustment ?
DemonGT
871
51
49
Sparta,WI
Clutch adjustment ?
iv had a Spec stage 3 clutch for awhile now but cant seem to get it adjustment right? im also using the UPR quad and firewall adjuster along with a TKO tranny
the tranny wont go into first unless i rev the motor some and it can also be a bear to get into reverse, has anyone else had similar problems? the clutch also engages really high up...
i have the quad on the 2nd hook and the firewall adjuster screwed out only a slight bit..maybe quarter inch or so...
iv also noticed if im at a stop sign with the clutch in and i try to put the tranny in first without revving, the car will move forward slightly
can someone school me on adjusting the firewall adjuster and what screwing it in and out dose exactly....
i just did alittle reading on clutch adjustment....
my problum is from what i read it said if the clutch is to tight it engages high..but if its to loose it can make it roll on flat surfaces and make it hard to put into gear...but i have both!!??
