N noslow1986 New Member Mar 25, 2006 274 0 0 oswego Il Apr 18, 2010 #1 Apr 18, 2010 #1 i went and got bolt size 1/4 -20x 3/4 and its to small and falls out the hole. its for a stock t5 trans. this is what bolt size there saying to use
Saleen0679 10 Year Member Apr 14, 2005 876 22 49 Yakima, WA Apr 18, 2010 #2 Apr 18, 2010 #2 Should be the correct bolt specs.
N noslow1986 New Member Mar 25, 2006 274 0 0 oswego Il Apr 19, 2010 #3 Apr 19, 2010 #3 bolt doesnt tighten just falls out the hole not sure its a dorman 1/4"-20x3/4 hex head cap screw if that helps
Saleen0679 10 Year Member Apr 14, 2005 876 22 49 Yakima, WA Apr 19, 2010 #4 Apr 19, 2010 #4 If you're sure the bolt you got is the right size then it could be someone previously stripped out the hole and tapped it for a larger size. If that's the case then you're going to have to try an assortment of different bolt sizes.
