Speed vs rpm
AdrenalineRush
18
Québec
I'd like to know the factory specs that each speeds will do at 6000 RPM... with a manual trany and a 3.55 final ratio. If somebody got them, what are the ratios of each speeds?
Another thing...is it true that disconnecting the connector on the rear end of the transmission (on the 5th gear?) will only cancel the speed limiter or it will do unwanted results?
Thank you!
Have a good day!
Adreline,
I have a excel spreadsheet. If you PM me your email address I will send it to you. You can change ratios, tire sizes to see the effects. Here is the sheet with the stock settings.
RPM 1st 2nd 3rd 4th 5th
1000 6.7 11.4 17.2 22.8 33.7
1500 10.1 17.1 25.9 34.1 50.6
2000 13.5 22.8 34.5 45.5 67.4
2500 16.8 28.5 43.1 56.9 84.3
3000 20.2 34.1 51.7 68.3 101.2
3500 23.6 39.8 60.4 79.7 118.0
4000 26.9 45.5 69.0 91.1 134.9
4500 30.3 51.2 77.6 102.4 151.8
5000 33.7 56.9 86.2 113.8 168.6
5500 37.0 62.6 94.8 125.2 185.5
6000 40.4 68.3 103.5 136.6 202.3
