Speedo cable/cluster...how does it attach??
Try to unbolt the cable from the frame to give some slack, plug it in and rebolt it. Thats what I had to do when i relocated the speedo cable toward the right for my 5 speed swap. I dont know if it would help for the older foxes.
I have this problem every time I plug the speedo cable on a Fox. Only thing I've found that helps it is if you either have someone rotate the other end of the cable until it pokes into there (the square peg into a square hole thing only works if it's lined up), or if you pull the gauge cluster out so you can rotate it a bit and wiggle that bugger into there. I've had to do it both ways, it's a royal PITA for something that would seem to be so simple. :fuss:
Push down on the flat part of the white plastic collar and pull the cable out.
Photos courtsey of ALMOST STOCK
attachment.php
attachment.php
