Speedo Cable Routing
  • Thread starter Thread starter limey66
  • Start date Start date Aug 16, 2005
L
limey66
408
Northampton, England
Aug 16, 2005
  • Aug 16, 2005
The PO of my 66 coupe took the speedo cable off the back of the instrument cluster, and now it is swinging about under the hood. I've looked for an obvious hole in the firewall to poke it through, but I can't see one.
Where is it supposed to pass through the firewall?
krash kendall
1,258
Aldergrove, B.C. Canada
Aug 16, 2005
  • Aug 16, 2005
I'll try to find out for you later.
steel1212
1,180
Frankfort, Ky
Aug 16, 2005
  • Aug 16, 2005
If I"m thinking right it comes in low on the firewall but goes through sort of a tunnel and comes out right behind the cluster. I'm not at my car right now to look but that is where mine went before I switched to a electric speedo.
krash kendall
1,258
Aug 16, 2005
  • Aug 16, 2005
It loops around above the steering column, coming down the firewall on the driver's side, then comes across to the right entering a hole between the accelerator and the column near the floor. From the bottom it comes out near the frame rail and routes fairly directly to the tail section of the transmission.
L
limey66
408
Aug 17, 2005
  • Aug 17, 2005
Thanks Krash.
So, is the hole just punched through the sheetmetal, or is it a 'tunnel'? I can't see anything on my car except for a largeish hole that the throttle linkage passes through - I could have been welded up I suppose...
It's items like this that just eat time out of your project!
krash kendall
1,258
Aug 17, 2005
  • Aug 17, 2005
Look waaay lower - below where the column passes through the firewall, towards the doghouse, near where the firewall transitions to floor. I can't give you an exact discription of the hole, as a PO glassed the entire floor and doghouse, but this is where my cable vanishes.
L
limey66
408
Aug 18, 2005
  • Aug 18, 2005
Thanks man.
I'll crawl under and take a look.
L
limey66
408
Aug 30, 2005
  • Aug 30, 2005
OK, I found a hole under where the steering column comes through - is that it? The PO has repaired the floor, and if there was anything below that point, it aint there now...
Edbert
3,548
32
109
Austin TX
Aug 30, 2005
  • Aug 30, 2005
I thought there was a small tube the cable went through, designed to prevent a kink or hard-turn. Maybe that is what was meant by tunnel?
Electric speedos are teh L337!
L
limey66
408
Aug 30, 2005
#10
  • Aug 30, 2005
  • #10
Yeah, I was looking for a 'tunnel' after that post, but all I can find is a hole just big enough for the nut to fit through...
WTF do I need a speedo for anyway, it's only ever going to be driven like I stole it...?
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Under-the-hood Wiring
  • Sparksteam
  • Sep 18, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 22, 2025
EP429
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
