Speedo Gear problems
  • Thread starter Thread starter 1FatPony
  • Start date Start date Oct 27, 2006
1FatPony
241
  • Oct 27, 2006
So I have 3.55 gears and my speedo is about 30% off. So I buy a 20 tooth speedo gear which is correct for an 87 5 speed with 3.55 gears. I go to install it and there is already a 20 tooth in there. Now what???
TRWXXA
190
RIGHT BEHIND YOU!!!... Made you look.
Oct 27, 2006
  • Oct 27, 2006
Perhaps you tranny was replaced or had work done on it, and you got a '90+ 5-speed or a different drive gear. The '90+ 5-speeds require a 23-tooth driven gear.
The alternative is to change the drive gear to one with fewer teeth.
Don't forget that non-stock tire size will have an effect too.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 27, 2006
  • Oct 27, 2006
The stock range of speedo gears work correctly with a limited range of tire sizes. The 23 tooth white gear works good for some guys, but self destructs in a few months for others.
See http://www.corral.net/tech/gearcalc.html for more help
Check to see if there is a speedometer shop in your area. If there is, ask about the Stewart-Warner speedometer gearbox. I believe it is either a 777 Series Drive Joint Kits and Parts or 666 Series Drive Joint Kits and Parts. It is a small gear box that fits between the speedo pickup gear on the transmission and the speedometer. It has quick change gears that allow you to choose almost any tire size and rear end gear ratio you want. This will allow you to get the accuracy within 1%-3%. The drawback is that it isn't cheap.
Please excuse the typo (their's, not mine) in the following picture - it should read Custom ratio adapters, not Custom radio adapters.
See http://www.gaugeguys.com/ratioadapt.htm for more info.
1FatPony
241
  • Oct 28, 2006
is it possible to look into the tranny through the speedo cable hole to see the other gear?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 28, 2006
  • Oct 28, 2006
Only if you like peep shows. Otherwise, you need an eyeball on a stalk like a snail.
There is limited visiblity through the hole. It would not be easy to count the number of teeth using that method.
back2fox
73
  • Nov 8, 2006
stock gear teeth from 86-89 T5 is yellow in color and have seven teeth. I have my tranny out right now and just looked at it. 90-95 T5 has eight teeth which is green.
Glaze
133
Gainesville, GA
Nov 8, 2006
  • Nov 8, 2006
break out your flexible mirror and flashlight bud
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
