Speedo Gear ?
  • Thread starter Thread starter kendawg73
  • Start date Start date Nov 30, 2017
K
kendawg73
Well-Known Member
Feb 5, 2014
474
102
64
Nov 30, 2017
  • Nov 30, 2017
I bought the speedo gear set for a 3.73 gear (this is for the T-5 tranny), well I see for the 7-tooth drive gear you have to remove the back part of the trans to put it on? (my trans is out of the car, along with the motor) but don't know if I want to mess with it, if I don't have to.... Is the stock drive gear already 7-tooth anyway? And if so, then I just have to pop out the stock speedo gear and install the 21-tooth one????
Steel1
Mustang Master
Aug 18, 2017
1,419
639
143
Connecticut
Nov 30, 2017
  • Nov 30, 2017
I think technically replacing both gears is the correct way to do it.
But when I did my 3:73 gears in my 93GT I didn't know about the drive gear so I just installed the
recommended driven gear and speedo is within 1-2mph when checked it against my nav.
Still going strong over 10yrs., but I can't remember exactly what gear I installed I think it
was the white 21 or 23 tooth.
Mustang5L5
Mod Dude
Feb 18, 2001
43,346
18,081
224
Massachusetts
Nov 30, 2017
  • Nov 30, 2017
THe 7-tooth was stock on certain years..up to 1989. After that is was 8 tooth.
Shine a flashlight into the speedo gear hole and look at the gear color. Yellow is 7 tooth. There is also a black and green gear for the 6 and 8 tooth drive gears but I forget which color is which.
If you have the 8 tooth gear, you can try a white 23-tooth speedo gear to compensate.
F
FoxChasis
20+ Year Stangneter
Dec 23, 2003
590
277
93
Dec 1, 2017
  • Dec 1, 2017
The speedometer "driven gear" is clipped onto the end of the speedometer cable. That is the easy one to change. The speedometer "drive gear" is slid onto and clipped to the output shaft (aka the "tail shaft") of the transmission. The shaft housing has to be removed from the transmission to change that one.
Reactions: General karthief
K
kendawg73
Well-Known Member
Feb 5, 2014
474
102
64
Dec 4, 2017
  • Dec 4, 2017
ok, thanks... I will see what's in there when I get ready to do it...(right now weather is cold, so looks like I'm done working on getting car back together until spring) so if I pull the rear housing (watch youtube video, doesn't look bad. to do, is black permatex good to seal it? if not, what is the best thing to use?
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Resolved Does anybody recognise this distributor gear?
  • x_man586
  • Jun 4, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
x_man586
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Drivetrain Speedo gear ate itself
  • keel
  • Aug 15, 2024
Fox 5.0 Mustang Tech Aug 15, 2024
AeroCoupe
