Speedo is off...could I have upgraded gears?
FireMedic90
Hi guys. I've been away awhile since I sold my 2005 GT, but I recently bought a 97 GT and on the trip home, I noticed something.
I was following my wife home and thought she was going pretty fast. I called her and asked her why she was doing 90. She said she was only doing 75. The tires are all 275/40R17's. But 1st gear also seems pretty short. Is it possible that the previous owner put some gears in this car? Is there any way to tell?
Thanks and good to be back! :)
Jack up the rear, turn the wheels 1 revolution and count how many times the d/s turns. That will tell you.
Good chance you have gears and they didn't put the speedo gear in.
What will the 1 turn ratio be? If I turn the rear wheels 4 times then should the D/S turn 10 times for 4.10's? Or is that not how it works? Forgive my ignorance here...:shrug:
If it's the case that I DO have gears, is there a way to correct the speedo problem? Will a tuner do the trick or will it need to have the speedo gear inserted regardless of the tuner?
Your will be looking for ratio's like 3.27:1 3.73:1 4.10:1 4.30:1.... Stuff like that. And yes. YOu only need to figure out what ratio you have then call someone like Latemodelrestoration for the correct speedo gear. Real simple to swap.
My car has been down for quite some time though I didn't replace my speedo gear and am going off of just memory--though I believe when driving 65-70, the speedo said 80 or in that area. I am basically just throwing out a guess :rlaugh:
5 speed car? Any other mods that are visible/audible?
Yea its a 5 speed. No other mods that I'm aware of. But I've only had it about 3 days. I'm about to put on a new tensioner pulley to replace the squeakin one I got. Bought it from here...
Spencer Performance Inc.
yea sounds like gears. I had the same problem when I bought my car. Even the previous owner had no idea and brought it to the dealer who then replaced the entire gauge cluster :rlaugh: fools
With 4.10 i was about 10-15mph over about that speed so when it read 90 I was going about 75ish if my memory serves right. Your best bet is to do what was already said or buy yourself a tuner and play trial and error until the speedo reads right. A tuner is a good investment anyway if you plan on doing anything. I love my predator. :nice:
Well 4.10's would definately explain why my gas mileage sucks! Even if it could be fixed with a tuner, I'd like to know whats in it.
But aside from the speedo, a tuner will work on a 97 right? I was thinking of one in the future. (lots of other stuff to do first!)
yes a tuner will work on your car for tuning it. Just won't correct the speedo. you will need a speedcal for that.
