  • SN95 4.6L Mustang Tech
Speedo not right
  • Thread starter Thread starter rage707
  • Start date Start date Jun 14, 2005
R
rage707
318
Springfield MA / Winston-Salem NC
Jun 14, 2005
  • Jun 14, 2005
Hey Everyone,
My speedo reads fast (says Im going around 50 when Im goin around 42). New gears would make it do the opposite right? Im tryin to figure out why its doin this and how to fix it.
Thanks
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jun 14, 2005
  • Jun 14, 2005
the factory speedos are always off a little. do you have gears in your car. i mean other than the stock rear end gears.
if no then you can try this using the WDS (dealer scan tool) it has a punch pad too sleect custom gear ratios. fine tun it untill you get the speedo dead on.
but before you do that check the PCM PIDS too make sure the computer is reading ti wrong. if it is reading 42 on pids when you are going 42 and the speedo reads 50 then leave it alone.
bham_gt
94
Birmingham, AL
Jun 14, 2005
  • Jun 14, 2005
Not if you went from say 3.27's to 3.73's. It would read higher than what you are actually going. My brother-in-law went from 2.73's to 3.73's in his 95 GT, and his speedo read close to 100 on the freeway when you were actually going around 70.
U
UNVMATT
294
COLUMBUS
Jun 14, 2005
  • Jun 14, 2005
3.27 to 4.10 - my speedo showed 85 and I was only going 60
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
  • Gulftown980x
  • Jul 29, 2026
squeak93
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
