Speedo Problem
  • Thread starter Thread starter Topdowncruise
  • Start date Start date Aug 30, 2006
T
Topdowncruise
207
Canada
Aug 30, 2006
  • Aug 30, 2006
My speedometer needle bounces as I accelerate and when I am at a stop light it doesn't go down to 0,it stays at about 10.otherwise the speedo is accurate.I had the cable lubed and it didn't solve the problem.Any ideas on how to fix?
N
noslow1986
274
oswego Il
Aug 30, 2006
  • Aug 30, 2006
did u check the plastic gear in the trans the speed o cable attaches to it and it goes inside the trans
T
Topdowncruise
207
Canada
Aug 31, 2006
  • Aug 31, 2006
Yes.I changed the speedo gear when i changed my rearend to 3.55's.The speedo problem existed before and after.
N
noslow1986
274
oswego Il
Aug 31, 2006
  • Aug 31, 2006
i had the same problem my speed gear the plastic one would get rounded out in the middle so i think mine problem is in the trans maybe u have the same problem
J
jeremey thomas
142
scottsboro alabama
Aug 31, 2006
  • Aug 31, 2006
its the speedo cable.ive had the same problem twice.the first time the cable sat on the h-pipe and a hole burned in it causing the fluid to leak out gradually,the next time it just got hot sitting close to the exhaust as i found a way to reroute the new one so it wouldnt touch.it worked great until then.now im on my third cable in a year and its starting to do it again.maybe ill just start going by my rpms.hopefully no tickets.lol
P
postalbunny
118
Sep 1, 2006
  • Sep 1, 2006
mabey different lube in the cable? I used the kind that came /w teh cable... but it still bounces sometimes. New gear, cable and vss AND speedo. I'm fixing to pull the whole thing again (to do fog light fix) and am going to try shooting lithium grease down the cable this time.
N
noslow1986
274
oswego Il
Sep 1, 2006
  • Sep 1, 2006
thats what i do go by rpms no problems yet
J
jslatts
68
PA
Sep 1, 2006
  • Sep 1, 2006
I have the SAME problem with my 1986, the Speedo wont go down to 0mph and it bounces
T
Electrical 93 Foxbody LX 5.0
  • TheJay806
  • Nov 16, 2024
Fox 5.0 Mustang Tech Nov 23, 2024
GTOreturns
G
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
D
Engine Throttle sticky even after cable replacement
  • dqureshi06
  • Aug 16, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
AeroCoupe
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
