I have a 1994 GT and i got some 3.73s. Anyway, i went to get my speedometer corrected and the guy said he needs to know how many teeth are on the current speedo gear. Does anyone know this?
When I put my speedo gear in (23T) I examined it & it didn't seem like the teeth on it were any thinner than the stock 19T one. Plus the old one which had probably been on the car since 88' didn't look worn out. What do you mean by "often"? I haven't had any problems with mine bouncing neither..FoxChasis said:(And even then, 23T driven gears aren't Ford gears, they're Chrysler gears and they're crap. The teeth are thin, ans they will wear out quickly. There'll be plastic bits floating in your transmission and the speedometer will be ouncing all over the place. Expect to change 23T driven gears often.) ..
krahkin said:There should be a 19-tooth gear in your stock configuration. Why not just get a SpeedCal? That way when you change tires, gears, etc. you can just flip a dip switch and have stock accuracy. Yes, I run one.![]()
