Speedometer off?
94whitestang
12
Oregon
I just got new tires and rims, I went from 15's to 17's....Someone told me that might make the speedometer off a little. I was wondering if this is true or not? Also it pulls way right, is that just the alignment? I'm going to get that done and I will see, I'm pretty sure thats it but I'm no expert. We'll see.
Thanks
Tom
Depends on the aspect ratio vs the width vs the wheel diameter of the tire. For instance a 245/40-17 has an aspect ratio of 40 meaning the sidewall is 40% of the width in height for each sidewall. So the 245/40-17 has a total height of around 24.7" as shown below. Now the height of a 205/60-15 rounded off to the nearest tenth of an inch would be identical in height as the 245/40-17.
Do the math:
245/40-17 tire:
245mm X 40% = 98mm for each side wall height.
2 sidewalls = 196mm.
Convert the 196mm to inches: 196mm divided by 25.4 (conversion factor from mm to inches) = 7.7 inches.
Add the wheel diameter of 17 inches + the 2 sidewalls of 7.7 inches = 24.7 inches total tire height.
205/60-15 tire:
205mm X 60% = 123mm for each side wall height.
2 sidewalls = 246mm.
Convert the 246mm to inches: 246mm divided by 25.4 (conversion factor from mm to inches) = 9.7 inches.
Add the wheel diameter of 15 inches + the 2 sidewalls of 9.7 inches = 24.7 inches total tire height.
