spherical strut problem...
  • Thread starter Thread starter twuxtop
  • Start date Start date Nov 13, 2005
T
twuxtop
50
  • Nov 13, 2005
see anything wrong?...the darn thing is bending under load. guess i gotta get out the welder and put a slug in her
thehueypilot
1,084
Medina,Tennessee
Nov 13, 2005
  • Nov 13, 2005
It looks like there is no weld on the top? Are you road racing causing the part to bend? Where did this part come from?
T
twuxtop
50
  • Nov 13, 2005
heres a pic white area is where it bent
the white area is stressed
O
Opentracker
20+ Year Stangneter
Feb 4, 2004
516
  • Nov 14, 2005
It looks like the inside pivot of the lower arm is too stiff and won't let the arm rotate with full suspension drop. Another reason why a spherical bearing makes a good pivot rather than rubber or poly bushing. Could be a reason too, why some stock strut rods break, instead of bend like yours did. Just a thought, I have never seen one bend like that before.
John
thehueypilot
1,084
Medina,Tennessee
Nov 14, 2005
  • Nov 14, 2005
I thought the strut rods were made out of spring steel to resist permanent deformation (bend)? If they are I would think that the weld would remove a lot of the spring-e-ness. The end that bent looks like it is not built from the original strut.
T
twuxtop
50
  • Nov 14, 2005
well
i have gw lcas with spherical, the strut rods are spherical, could this happen from a misalignment?
66Runt
680
Nov 14, 2005
  • Nov 14, 2005
Some guesses
Just some guesses,
I am wondering with the inner spherical bearing if under heavy braking force, you are not getting a twist that is bending your strut rod.
Or if you have power steering could turning the steering hard against the stop be twisting your LCA and bending the strut rod?
Or some kind of combo of the two? Or maybe turning tight into a driveway or over a bump with the steering wheel turned tight against the stop?
I would definitely like to hear what you find out though! I've got very similar components on my car, it just hasn't come off the jack stands yet. If there is a lesson here, I'd rather learn it from you than from myself.
Whose brand strut rods are those?
Scott
CochinoFilipino
171
CA
Nov 16, 2005
  • Nov 16, 2005
Well he says 'gw lcas' so I'm thinking Global West.
twuxtop said:
i have gw lcas ,,,,,,,
Twuxtop, Maybe you should call Global West and see what they have to say. And please share with us whatever you find out.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Nov 16, 2005
  • Nov 16, 2005
If the problem would bend the GW arms, I would hate to see what it would do to stock arms.
Jester67
908
TN
Nov 17, 2005
#10
  • Nov 17, 2005
  • #10
That is not a Global west arm it looks like a street and track from the limited photo. I think he was saying the LCA was GW.
T
twuxtop
50
#11
  • Nov 17, 2005
  • #11
i jacked it up from the lca near ball joint, set her back down, no more bend, i will keep my eyes on it, still not sure if a mis alignment is the culprit, part seems fine, but a few super tiny hairline paint cracks
Jester67
908
TN
Nov 17, 2005
#12
  • Nov 17, 2005
  • #12
Who made the strut rod?
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Monday at 5:18 AM
manicmechanic007
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
