Spintech Side Exhaust Installed
281pony
2,681
Oly, WA
couldn't get it finished yesterday due to subframe clearance. finally got the subframes off, and finished the install. everything went smoothly except the bolt on the side pipe they give you is ****ty quality. i was barely turning the bolt to crimp it on there and the damn head snapped off. i went to the hardware store and spent 2 bucks for some real ones and it went on awesome.
the site is down for uploading pics so ill have to do that later. the sound is awesome, very deep throaty sound with bbk equal lengths, offroad h-pipe and the spintechs. it doesn't get the droan that my flowmaster 2 chambers had when sitting at 70 on the freeway. just a more consistant clean sound
denting the pipe or grinding subframes is out of the question. the pipe is already pressed for clearance from spintech and it is still probably an inch too thick to bend around the subframes. so either remove them or buy spintechs if you still want them.
the only thing i am not 100% satisfied with is how far the pipes stick out under the ground effects. they come out about 3 inches, im going to get some 2000 cobra R style tips welded to fit on there soon though, so it will look alot nicer.
ill try to get some pics up again later
