SPOUT connecter.
  • Thread starter Thread starter MusPuppis
  • Start date Start date Nov 29, 2004
M
MusPuppis
136
Lexington, Ky.
Nov 29, 2004
  • Nov 29, 2004
Taking the truck in to get the timing worked out today but ive read that I should set the timing with the SPOUT connecter out, then reinstall it when I'm done.
Where and what is it exactly? heh. Also, should I remove it when I zero the engine itself in or when I'm getting the distributer where it needs to be?
M
MusPuppis
136
Lexington, Ky.
Nov 29, 2004
  • Nov 29, 2004
Ok.. I forget theres a search function from time to time.. bleh.
I got it in another thread. Id just like to confirm something. The SPOUT Connector is the plug that connects the distributer into the engines wiring harness?
TT91
1,536
Paramus, NJ
Nov 29, 2004
  • Nov 29, 2004
the spout is a little grey or black plug that is very near the distribor harness. Its a little piece of plastic that plugs into the dist harness. Do not disconnect the distributor, rather, gather up the elec harness from the dist and finger it along until u come along this little plastic "spout"
ninety15.0
1,336
  • Nov 29, 2004
Yea....the spout connector isnt actually a connection at all. Its simple a small wire with a dead end grey plug cap on it that is part of the distributor harness. Find the TFI connection that plugs into the distributor and then just trace it back until you find the small grey cap on a 3 inch long dead end wire. good luck man
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
