Can the spout be plugged in backwards? I had to extend the lines for it, and both lines looked the same I didn't keep track of which side was which. Now the spout doesn't seem to do anything. I'm showing 10* timing whether it's plugged in or not.
All you need to do is splice the wires together and your set. I just put a switch on mine. One way = spout out, switched the other way = spout in. Nice and simple.
I soldered the wires together so the should be good. I'll double check it with the spout in and out. If that doesn't do anything, I'll try switching the wires just for s&g.
