spout out total timing
If talking about running locked-out timing, I ran mine at 28* for a summer (115*F temps, 87 octane, yada yada).
The timing reading stays the same when you do this. You remove the SPOUT connector, set the timing where you want it targeted (26*, 28*, etc) and leave the SPOUT connector removed.
Now you run around with the timing where you set it. So mine was at 28* at idle, at 6K RPM, and every where in between. THe EEC had no control over it.
And since I think I'm misreading the question, I set it at idle. Then ran the RPMs up and watched that the timing wasn't changing and was where I wanted it.
Here is the deal with spark and sbf's :)
With good gas ;)
You'll make the most wot hp with a total amount in a range of 36 .....
give or take a few.
This is said disregarding any advancement methods no matter if we are talking
about a little silver box we have today or even old school methods such as
bob weights or a vacuum canister hanging off the side of a dizzy.
Again this is with high octane and a race or wot application
Now ... this is not gonna be all that practical for a street application
In all honesty ... these days the spark is controlled by the pcm and
during very light load driving conditions, you will see spark values
well over 40 :eek:
RPM is also in control of spark values :D
When one does the pcm-less timing thing :shrug:
They don't get those benefits :(
Might ... again ... Might ... make more wot hp
but
Won't run as smooth during most other driving conditions
Hey ... try it and see :nice:
Just don't go hog wild on the spark at first :nono:
especially
If all you got is that weak Kool Aid stuff they call gas up North :rlaugh:
Grady
