Spring Install
  • Thread starter Thread starter xpeteyjtx
  • Start date Start date May 26, 2006
xpeteyjtx
108
Taunton, MA
May 26, 2006
  • May 26, 2006
I am getting ready to install my Eibach springs and have a few questions. I have heard of a method for removing the springs, but just want to make sure that it will work. I was thinking about putting the car up on jack stands, supporting the a-arm with a floor jack, removing the strut, and then slowly lowering the a-arm until the spring falls out. Installing would just be the reverse. I did do a search and found a few different methods, but I do not want to unbolt the a-arm and I cannot find or afford a Ford spring compressor. Will this work? Thanks for the help in advance!
83Mustang427TT
162
  • May 26, 2006
Im not gonna say if that will work because if you get hurt It could be my fault ....but thats how I did mine same with the back springs support the car with jackstands put the jack under the lower control arm put a lil pressure on it unbolt it lower it down slow and swap the springs and rubber isolaters..a trick to do the front is if you have an impact gun take and put an 18mm on and just take the main center strut bolt out and lower it down..I did mine in 45 mintues.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
