Springs Isolators making noise....HELP!!!
ronjon
25
I had Mac springs installed and now when I hit a small to medium bump or when I push the back of the car down with force you can hear the rubber isolators making noise. At least that's what I it sounds like to me. I also had rear/upr control arms installed at the same time.
Is there a quick and easy fix for this??? I was thinking of coating the bottom of the spring where it meets the isolators with oil...
What kind of sound, a creeking sound, or a banging sound. If you think its the springs creeking, Im sure you could spray a little white lithium or something on the springs. Did the control arms you had installed have polly bushings? Do they have grease fittings on them?
I took mine out completely cause I have the same squeek sound? Worked alot better no noise at all. I am going to put the isolator back on the upper rear spring. A little rattling noise going on the bumpy freeway here in Seattle. Other than that it is pretty solid.
