For the guys that have done it. Have you torn the motor down afterwards to check the bearings? Mine was off about 40-50* so I'm a little curious if I should bother to pull the pan and check
the balance factor is built into the part that connects to the crank, not the ring that is attached by the rubber. thus there should be no damage to the bearings.
I guess this is why your timing was so far off at the track the other day. Man, that sucks. Hope everything is okay.
Joe
no its not...its on the outter ring
Plugs? You mean there is more than one?Oil pressure is fine... I'm going to drain the oil tomorrow and check the drain plugs.
I'm kidding of course, lmaoFront and rear lol
Hell the turbo car is the same way
