  • SN95 4.6L Mustang Tech
Squeak
  • Thread starter Thread starter 04sonicblueGT
  • Start date Start date Jun 29, 2007
04sonicblueGT
80
  • Jun 29, 2007
i have a squeaky sound from under neath the car, when i was under the car while it was running it sounded like it was coming from the front passenger side of the transmission ( manual) the sound is effected by rpm's( higher rpm= faster squeak ) i noticed that at the connection of the transmission to my drive shaft there is fluid leaking but it doesn't look like much. I am thinking the sound might be from low fluid in the tranny but there isn't really a way to check that i know of.
Any ideas? should i try adding some fluid.
Car has about 45,000 on it. (2004)
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jun 29, 2007
  • Jun 29, 2007
does the squeak go away when you push the clutch pedal down?
If it does then it's the TOB and the transmission needs to come out to replace it.
04sonicblueGT
80
  • Jun 29, 2007
no it is not the TOB, it doesn't go away when clutch is in. It is not a very loud sound, it is actually hard to hear over the exhuast but when i was under i could hear it well.
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
C
1992 LX 2,3, automatic problems, oil dissapears.
  • Carpimp
  • Aug 10, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Aug 10, 2025
General karthief
