Squeaky Front end
Russell Withrow
I know this question has been asked a million times but I don't seem to be smaty enough to fix it. My 89 GT 5.0 Convertable has a terrible squeak in the front end and I can make it do it by pushing down of either front fender. I have replaced struts, Rack and Pinion bushings and a right tie rod end and strut mounts. The wierd thing is the car was quiet for three days after I replaced the strut mounts but came back with a vengence the fourth day. What is my problem?
Squeaky Russ
Did the strut mounts settle after the suspension jounced for a few days?
Otherwise, FLCA bushings are something to inspect and consider.
Good luck.
I had an annoying squeak in my front last year and replaced several bushings (they needed it anyway) but the culprut was the sway bar bushings and end links. One way to tell is to jack up the front, put it on jack stands with tires still on. Then take your jack and raise and lower the tire with the jack. Look and listen for the squeak.
Could also be a dry ball joint. My front left is squeaking really bad. Slit open the boot and got some oil into it and the squeak went away. But I'm not messing around with a ball joint because I dont really need my tire to fall off going 100mph.
