  • SN95 4.6L Mustang Tech
squeeky rear end
  • Thread starter Thread starter EriMon
  • Start date Start date Nov 30, 2004
EriMon
39
Riverside, CA
Nov 30, 2004
  • Nov 30, 2004
everytime i go over any sort of bump or even little descrpancies in the road my rear end squeeks. Sounds like someone havin sex on an old bed. heh.. I'm still under warranty so i brought it to the dealer to have them look at it. They said that the noise is coming from the aftermarket trailing arms. I'm new to the mustang platform. What are trailing arms and does anyone know where in the rear i can find them. Ford told me to have them lubed up and the noise will go away.. but they wouldn't touch it because it's not factory. Sheisty bastards.. lol
40th GT
916
Lawrenceville, GA
Nov 30, 2004
  • Nov 30, 2004
I'm guessing that trailing arms are what we call control arms. Since you don't know what they are, I assume that you didn't buy the aftermarket ones. I would start out by changing the control arm bushings. It may not fix the problem since the aftermarket arms are most likely the culprit.
merc123
420
North GA
Nov 30, 2004
  • Nov 30, 2004
Mine was the same. I got a "no problem found" from the dealer.
dmarco_4u
194
  • Nov 30, 2004
WD-40 BABY!
jmk97GT
178
  • Nov 30, 2004
Are they positive thats the problem? I had the exact same sound in my car but it was actually the exhaust pipe rubbing against the axle.
EriMon
39
Riverside, CA
Nov 30, 2004
  • Nov 30, 2004
I have stock exhaust. Do you really think it'd rub?
EriMon
39
Riverside, CA
Nov 30, 2004
  • Nov 30, 2004
hey, if I want to lube these bushings, what am i using? jsut regular axle grease or wd-40 or something?
EriMon
39
Riverside, CA
Dec 13, 2004
  • Dec 13, 2004
bump
R
Rocketman
730
SoCal
Dec 13, 2004
  • Dec 13, 2004
After I put in my MM full length SFC, all the squeaks went away!
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
M
Rear end sounds like marbles in a tin can.
  • MacMAgoo
  • Oct 30, 2022
SN95 4.6L Mustang Tech Nov 18, 2022
TIGGER
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
SOLD MM coil overs, koni struts, qa1 rears, h&r rear springs and more in NJ
  • 2000xp8
  • Mar 15, 2023
  • Suspension Parts
2K
Suspension Parts Mar 20, 2023
2000xp8
