  • 1994 - 1995 Specific Tech
sry guys, holley systemax?
  • Thread starter Thread starter jawsgt
  • Start date Start date Oct 12, 2005
J
jawsgt
18
ohio
Oct 12, 2005
  • Oct 12, 2005
is the kit worth it or can u piece a better heads intake cam combo together for less. as of rite now ide like to by spring time be running high 12's if possible with a h/c/i setup. i'll be saving my penny's for a 347 stroker over spring time. wut does a h/c/i 347 run on average? low 12's high 11's?
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
Oct 12, 2005
  • Oct 12, 2005
I've heard good stuff about it, but it seems very very few people are actually using it.
I'm pretty sure it is meant for higher RPM applications, but not 100% sure.
You might want to try out one of the trickflow top end kits
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Oct 12, 2005
  • Oct 12, 2005
The holley shines in upper rpms....not really a low in the rpms torque monster. It is even better on blown applications.
But with an intake like that and a smaller stroke motor(302) you just need a good cam to make it all work.
Killercanary
The car that set the bar.
Altoona, PA
Oct 13, 2005
  • Oct 13, 2005
That kit will work great though down the road with the 347. Its a good kit. My dad has it on his '91Gt and with just the kit and the normal bolt-ons he was running 12.6 at 107mph. He then had the heads and intake ported, new standard bore pistons installed (for PTV clearance), a custom FTI cam, and the heads were milled. He is now putting down 346rwhp/338rwtq and has run 11.8 at 117mph so far, and that is at 3350lbs.
EDIT- this is with a 302, not a 347.
super302
May 29, 2004
2,878
Davenport, IA
Oct 13, 2005
  • Oct 13, 2005
he has a 302 correct??
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Oct 13, 2005
  • Oct 13, 2005
i didnt even see you were gonna run a 347. If thats the case then the holley will do fine. I heard the heads and intake were great and the cam was alright. Pauls dads car is a perfect example and thats still a 302 im pretty sure.
Killercanary
Altoona, PA
Oct 13, 2005
  • Oct 13, 2005
Yes he does. He bought a new stock block and reinstalled his crank and rods along with a set of standard bore SRP pistons and a main stud girdle. The combo is now a perfect match for a 347 cubic inch stroker... he won't have to upgrade anything except maybe the exhaust.
If he can maintain the HP/cube he has now he should have a 400rwhp 347 on his hands.
Zero Signal
2,633
Tucson, AZ
Oct 13, 2005
  • Oct 13, 2005
I think those Holley heads though are really more of a nitrous head with that low intake/exhuast flow differential. If you were to go with the nitrous and the cam for it, you'd have the perfect head.
illwood
636
Worcester, MA
Oct 13, 2005
  • Oct 13, 2005
Paul, once again you give me faith on running a 302/306cid car with h/c/i and the proper tune (and driver) getting to the 11s.
J
jawsgt
18
ohio
Oct 13, 2005
#10
  • Oct 13, 2005
  • #10
hell yea mayb i'll look into gettin it now. that'll be close to wut my trans am ran which wasnt to bad, 12.5@112
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
21K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
