  • SN95 4.6L Mustang Tech
Stage 3 cams
  • Thread starter Thread starter Green&GoldGT
  • Start date Start date Aug 25, 2006
Green&GoldGT
302
Virginia
Aug 25, 2006
  • Aug 25, 2006
I've decided that my next mod is gonna be Crower stage 3 cams. I was wondering if I would have any piston to valve clearance issues or any other problems if I had them installed? Which valvesprings can I run with the cams-Crower, Manley or Comp? Do I need to buy aftermarket cam gears? What is the maximum safe rpm I can run on my stock shortblock with the cams?
Thanks for any input.
DropTopPony
Noob Slayer
2,570
south jersey
Aug 25, 2006
  • Aug 25, 2006
Those cams are alittle much for the mods you have don't you think? Bigger isn't always better...
stangGT97
1,299
Boston area, MA
Aug 25, 2006
  • Aug 25, 2006
If your cams are degreed properly, you shouldn't have PTV issues. The max you want to rev your stock block on a regular basis is around 6200 rpm, just make sure your oil level is always spot on, or you'll run into serious issues. I can't comment on the springs though, maybe someone else can help. I do agree with DropTop though, these cams may be too much for your current setup.
04YELLOWGT
1,135
Indiana
Aug 25, 2006
  • Aug 25, 2006
I would say thats too much also, I thinh the stage 2s would be more than enough. Espically if its a DD.
O
Orange04BOSS
108
Denton, Texas
Sep 26, 2006
  • Sep 26, 2006
what happens if the cam is too much what does that mean.
R
Rocketman
730
SoCal
Sep 26, 2006
  • Sep 26, 2006
Means without a good set of high flowing heads, good exhaust and a good intake, a stage 3 cam is a waste.
lvmustanggt
721
Las Vegas
Sep 26, 2006
  • Sep 26, 2006
I got comp cam XE270AH-13. It's like stage 2 cams and I am very happy with it. I get props allmost every stop lite and yes it's my DD
oxfordgt
288
Clarksville, TN
Sep 26, 2006
  • Sep 26, 2006
You are going to kick yourself if you buy and install stage 3 cams on your car. You dont have enough done to your car to get any use out of them. You are going to lose alot of bottom end hp and torque. Stage 3 cams are only good for high reving engines and yours is stock so you will not be able to rev to where you will get a gain. Also you will need ported heads, upgraded intake, upgraded oiling system and longtubes. Dont forget a forged shortblock
Stick with the stage 2's
Did you not change out your springs when you put in stage 2 cams? manley nextek are the best springs right now.
O
Orange04BOSS
108
Denton, Texas
Sep 26, 2006
  • Sep 26, 2006
I am comparing vt stage 2's to the crower high lift stage 2's. the numbers are from vtengines and from crower.com. here they are.
vt stage 2 na are .560/.575 lift, 225/235 .050 duration, 108 lsa.
crower stage 2 high lift is: .559/.570 lift and 208 lobe 212 over 224 valve 228 with duration at .050. Now they do have an adv duration number which is 254 lobe 258 and 268 valve 272.
I don't understand the numbers. I see that one is more than the other but what does that mean. Thanks. As for the crower cams I see that they have two different durations but not sure what that means. Thanks.
san~man
O-G
A little grass shack on a big lava rock
Sep 26, 2006
#10
  • Sep 26, 2006
  • #10
There are a few threads on the Fidanza gears....read up first before you buy them.
T
TGJ
1,049
#11
  • Sep 26, 2006
  • #11
DO NOT BUY the Fidanza Cam gears or the Comp Cam gears for that matter, they are the same thing. There is people who have lost their motors due to the Fidanza cam gears breaking, causing PTV contact.
jasonh_86
I
May 20, 2005
1,156
Arkansas
Sep 26, 2006
#12
  • Sep 26, 2006
  • #12
Stick with your current cams man. But the Manley Nextek's are great springs and support up to .580 lift, where the comp springs only support up to .550 lift.
BlackenedSVT
1,841
New Jersey
Sep 26, 2006
#13
  • Sep 26, 2006
  • #13
You already have stage 2s and you want to upgrade to stage 3s now? That sounds like a HUGE waste of money if you ask me....unless you are doing the install your self...but parts alone sounds like a waste of money. Put the time and cash elsewhere
stangGT97
1,299
Boston area, MA
Sep 26, 2006
#14
  • Sep 26, 2006
  • #14
yes, I saw those threads on MD. I retract my statement, I didn't know they were that craptacular. A good concept, but a very sub-par quality product. I edited my post to reflect this info, don't want people buying those and destroying their motors
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 4 5 6
2K
Classic Mustang Specific Tech Thursday at 6:10 AM
DadLife0724
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
