  • 1994 - 1995 Specific Tech
Stalling & No-Restart
  • Thread starter Thread starter karl95gt
  • Start date Start date Jun 21, 2006
K
karl95gt
  • Jun 21, 2006
First time poster here......here is my situation: (95 GT)
I can drive the car for about 30 minutes, park it for about 20 and it will not restart. It will crank and crank though. I can still here the fuel pump turn on though, my presumption is that I am still getting fuel pumped up to the rail(?)
Here is the list as to what has been replaced.
Cap, rotor, wires and plugs
PIP Module
Ignition Module (the one under the air filter assembly)
Coil (got an Accel unit)
fuel filter
The car is mildly warmed over. It has the Edelbrock performer 5.0 intatke and corresponding power package (cam, etc.), complete exhaust - true duals, no cats.
A possible suggestion was the car was experiencing vapor lock from the gas lines being so close to the exhaust stuff. (just throwing that in FWIW)
Any help would be appreciated.
Thanks guys,
Karl 95GT
95Vert
1,785
North Mexico (deep south Texas)
Jun 21, 2006
  • Jun 21, 2006
Someone told me that their solution to this problem was a new dizzy. It would do the same thing as yours. A buddy's car is doing the same thing, and that is our next step.
HISSIN50
34
129
Jun 21, 2006
  • Jun 21, 2006
Welcome to the board Karl. With the high pressures our fuel system uses, you'd be hard pressed to experience vapor lock.
WHen it wont start, check for spark and injector pulsing.
Good luck.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Zero fuel pressure @ Shrader, but over 100 PSI at filter
  • Stang337
  • Jul 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 10, 2025
JD1964
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
