  • SN95 4.6L Mustang Tech
Standard or Full Length SubFrame Connectors?
  • Thread starter Thread starter SRT Handz
  • Start date Start date Jan 31, 2006
First Prev 2 of 2
F
flipnsac
159
Northern CA
Jan 31, 2006
#21
  • Jan 31, 2006
  • #21
Full..............and remember to use a lift that supports the wheels when welding on the SFC's.
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Jan 31, 2006
#22
  • Jan 31, 2006
  • #22
Do full length and shut up. Consider yourself lucky that you can add MM SFC! I on the other hand, choice of SFC that I can use is very limited(which I,m getting ASA my tax return gets here
Stang|ess said:
Looks like you have plenty room for cats.
I think he might be thinkinga about these thing...
xseler8
619
Montgomery County,Pa.
Jan 31, 2006
#23
  • Jan 31, 2006
  • #23
MMFL
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Jan 31, 2006
#24
  • Jan 31, 2006
  • #24
hognutz said:
Do you have a panhard rod or spherical bearing control arms? if you don't have something to locate the rear axel better you won't notice the subframes as much.
there are multiple problem areas on a mustang. rear axel location is the most overlooked problem IMO. could not belive the differenc the MM drag arms made on my car. In hindsight I would have bought the parhard rod as well.
I swear, this car is a money pit
It might be because I have a metal ass. Couldnt tell a difference when I changed my midpipe. Well other than that I lost low end power, but couldnt tell a difference up top. Then, when I installed my LTs, I couldnt tell much of a difference.
Springs, shocks, and struts I could notice.
Survey says! full length!
AdRock
521
South Texas
Feb 1, 2006
#25
  • Feb 1, 2006
  • #25
propellerhead said:
I don't agree with the 'night and day' thing either but I'm sure it helps in the long run. If yours is a daily driven car, you may not get much out of them. If you occasionally go to the track and hit it hard, they'll help keep your car straight.
It all depends on where you drive.
At my last job I parked in a parking garage. Before installing the subframes I could feel and hear the body twisting when i turned up the ramp. Once the subframes were installed there was no more flex and the car felt much more stable when on uneven surfaces.
menasci
640
Chandler, AZ
Feb 1, 2006
#26
  • Feb 1, 2006
  • #26
Stang|ess said:
Reading comprehension > some of you folks
Writing skills and the ability to form a proper sentence > you
First Prev 2 of 2
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
9
New from northern MN
  • 91firecracker
  • Apr 19, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 19, 2026
E
New Member with 91 foxbody
  • EricMac13
  • Jul 22, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 23, 2025
EricMac13
E
F
Pcm ground connector
  • fox1990
  • Jan 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 12, 2026
Mustang5L5
