Stang shutsdown after startup
  • Thread starter Thread starter RUSH2112
  • Start date Start date Oct 18, 2004
R
RUSH2112
22
Pittsburgh, PA
Oct 18, 2004
  • Oct 18, 2004
When I start the car it fires up but IMMEDIATELY shutsdown. I bought a new coil. The plugs, wires, cap and rotor were replaced last week. I replaced the IAC valve with a new one. I also replaced the TPS unit and still no luck. I replaced the fuel filter and I can manage to keep it going if I give it gas, however it sputters, backfires, spits, farts, burps and sounds like crap.
I do know the cat converters are possibly clogged and/or the OS sensors need replaced. Anyone have any ideas? HELP PLEASE!!!! What would be your next move?
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Oct 18, 2004
  • Oct 18, 2004
If it ran good before you replaced all this stuff, I would check the firing order on the wires. also what did you gap the plugs to?
R
RUSH2112
22
Pittsburgh, PA
Oct 18, 2004
  • Oct 18, 2004
Yes, it ran fine when i did the plugs, wires, cap and rotor. The plugs were gapped to spec. It just 'all of sudden' wouldnt stay running, so that's when I started changing all the other parts.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 18, 2004
  • Oct 18, 2004
I would check the eec for codes. If you have a fuel press guage also check the pressure on the rail.
jadedinpa
1,094
lancaster, pa
Oct 18, 2004
  • Oct 18, 2004
try holding the ignition switch just a little bit towards crank. my ignition switch went out and did basically the same thing.
R
RUSH2112
22
Pittsburgh, PA
Oct 18, 2004
  • Oct 18, 2004
I had it in the Ford shop and no codes were found. I dont understand the crank thing. It turns over and will start, but I have to give it gas to keep it running otherwise it shutsdown. Also alot of exhaust is coming from the pipes and a bad, rich smell.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 18, 2004
  • Oct 18, 2004
maybe the fuel press reglator went bad and it is flooding out.
R
RUSH2112
22
Pittsburgh, PA
Oct 18, 2004
  • Oct 18, 2004
I dont have a fuel pressure guage, nor would I know how to check this. The Ford shop said it have good fuel pressure, but I guess it could have 'gone' since then. I am not mechanically inclined very much, nor do I know much about cars, so I am backed up against a wall here.
R
RUSH2112
22
Pittsburgh, PA
Oct 18, 2004
  • Oct 18, 2004
Where is the fuel pressure regulator?
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 18, 2004
#10
  • Oct 18, 2004
  • #10
the regulater is on the passinger side behind the throttle body mounted on the fuel rail. right behind the salt and pepper shakers (10 pin connectors)
R
RUSH2112
22
Pittsburgh, PA
Oct 18, 2004
#11
  • Oct 18, 2004
  • #11
I think I am seeing what your describing, however this is located directly under the salt/pepper shakers. YES???
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 18, 2004
#12
  • Oct 18, 2004
  • #12
Yeah kinda under them. Its round and should have a vacume hose on top of it
R
RUSH2112
22
Pittsburgh, PA
Oct 18, 2004
#13
  • Oct 18, 2004
  • #13
Yes, it has a red color line that runs to the back of the plenum, although it doesnt want to come off too easy and I don't want to break it. How do you remove the fuel regulator? Looks like the bolts/screws are on the bottom....
89lxsport50
550
Franklin Tennessee
Oct 18, 2004
#14
  • Oct 18, 2004
  • #14
Sounds like the fuel pump or the regulator. The easiest way to remove the regulator is to pull the upper intake. Some folks with tiny hands and loads of patients will try it without pulling it, but that's not me. It is held on the fuel rail by 3 allen head screws. Before you try to take it off pull the vacuum line off it and see if fuel comes out. I am pretty sure that if fuel comes out it is bad. If you decide to replace the regulator, relieve the fuel pressure first. If it is not the regulator, I would suspect the pump.
cobradvm
245
Woodinville, WA
Oct 18, 2004
#15
  • Oct 18, 2004
  • #15
I would think that if it was running fine before you did your plugs, wires, cap and rotor, then that is where your problem is. I would first check your firing order - the order should be 1 3 7 2 6 5 4 8 in a counterclockwise direction. The number 1 cylinder is on the passenger side at the front, and goes 1, 2, 3,4 front to back, then 5, 6, 7, 8 on the drivers side front to back.
If that doesn't work, then you will need to recheck that you are at TDC on cylinder 1 when the rotor is at the #1 spark plug boot on the dizzy - that should be fine though since you didn't pull the dizzy I assume.
EDIT: I re read your post - I think what you said was that after you changed the plugs, cap etc it WAS running fine. If that's the case, then disregard what I have written above, although it is never a bad idea to recheck that stuff.
Howard
MurdockSVT
703
Wisconsin
Oct 18, 2004
#16
  • Oct 18, 2004
  • #16
welcome to my world rush2112
I have tried everything. except replace the fuel pressure regulator. I will let you know lol.
Michael
R
RUSH2112
22
Pittsburgh, PA
Oct 18, 2004
#17
  • Oct 18, 2004
  • #17
Let me know MurdockSVT. I am going to pick up a fuel regulator tomorrow and will replace it tomorrow nite. I'll let you know as well.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Popping noise in the intake. Frustrated still.
  • esteban31065
  • Apr 6, 2025
Fox 5.0 Mustang Tech May 23, 2025
gkomo
