StangNet '11 5.0 Notch Project
I wanted to post our Swaybar setup for those that are still pondering fitment of such.
Parts:
Stock FOX Swaybar (diameter being stock is critical, ie; oversize is not going to work)
SN95 Sway Bar Mounts - These are the ones that lower the swaybar and are 2pc contruction
FOX Swaybar Bushings and Endlinks
Maximum Motorsport Swaybar Lowering Kit
Setup:
Our engine setup has the Alternator in the Coyote stock position (driver side lower)
Power Steering Pump in the Coyote Stock A/C location (I imagine if the A/C Compressor was here this would still work)
Mount the MM Swaybar Lowering/Movement kit so that you are moving the swaybar rearward 1/2". It has bolt holes where you can configure/manipulate for this to work. This will also lower the swaybar by 1" and move it back 1/2" for clearance.
Mount the swaybar SN95 Brackets and the stock FOX Swaybar to the MM Mounts.
On the Endlinks, you are going to need to shorten the spacer tube because the swaybar is now lower by 3 1/2" - 4" (I can't exactly remember). We also had to obtain some 3/8" Grade 8 bolts 6" long, as the stock or aftermarket Fox endlink setup is too long. Make you get the correct thread pattern for the endlink nuts, I think it was x24
I can't remember off the top of my head... BUT measure from the bottom of the FOX frame to the top of the bushing (the top facing flat side) in the brackets once they are mounted to the car. This is HOW MUCH you have lowered the swaybar, so you need to cut that much off of the spacer tube that goes over the bolt for the endlink setup. I think I took 1/2" less off the computed number, as I would start longer then go shorter if needed but it seemed to work well as is.
Hope this helps anyone out there looking for a solution.
Any info on the Paint? Is it a single stage or a satin?
I see you listed the color code as Sterling Gray Mattalic.
Could you possibly link the seller you bought it from?
Any info on the Paint? Is it a stage one or a satin?
We used PPG paint. So basically a normal base coat of Sterling. Then 2 coats of PPG Flex and Clear Satin... but you can only do 2 coats of clear, as it will then become to foggy... mix ratio of 4:1:1. Warning though, for a daily driver I would not suggest this paint. It will (anything like paper, clean too hard, etc) make shiny spots and then any scratches cannot be buffed out. Looks good though if taken care of. ;)
Mike
Mike
Hmm. Thanks for the info, oh and another thing, those door speakers, are they from kicker? And did you have to cut the hole bigger?
