started my H/C/I swap on my 93 vert
steelie4u
78
well i stripped the engine down and now am prepping for the install i am installing AFR 165 heads, trick flow stage 1 cam , new timing chain, new 1.6 rockers, new roller lifters, new hardened pushrods, trick flow street heat intake, fuel regulator, fuel gauge, and 255 fuel pump along with 24 lb injectors, and pmass MAF calibrated for 24 lb injectors, cant wait to see the difference, i will try and get some pics up , also installed high torque mini started from PA performance
