I have a 69 coupe that was an c6 auto and 302 that ran fine and I swapped a roller 302 and a t5 into. Now every time I start the car by using the ignition switch the starter stays engaged and won't disengage however if I start the car using a remote starter hooked up to the starter solenoid it starts fine. When I started the car with the ignition switch I put a wire in the plug at the firewall of the neutral safety switch between the two posts to jump it, and I think this is where the problem is because I opened up the ignition switch and it was fine. So I guess my question is how do I bypass the neutral safety switch since there's is nothing plugged into it now that I'm running a manual transmission?
