Starter or Flywheel/Flexplate - '66
hivewax
233
Miami, FL
Starter - '66
i turn the ignition and the engine doesn't crank... the starter just "whirrrrs." yesterday morning, it did it once, but i started the car the second time. It progressively got worse thru-out the day. luckily, i made it back home. now, i can't get it in the garage... car is sitting in the driveway. searched thru the forums, some said it could be bad starter or gear teeth on the flywheel/flexplate. what is the problem?
What's changed? Did you replace starters recently or has this been an ongoing problem thats gotten progressively worse. Pull the starter and look at the teeth and if they're ok take the starter to a shop and let them test it. It only takes about 10 minutes to pull it.
Could be a matter of missing teeth, but it's more likely to be a bad starter drive. That's the mechanism inside the starter that forces the gear out to engage the flywheel. As 1966conv said, it's a simple matter to remove it and test it.
I'm betting it's the starter not kicking out all the way, but it could be the teeth. If you or some past owner tried to start the car while it was running, it could have damaged some teeth and if the car stops on that spot on the flexplate, it has nothing or little to engage to.
You can pull the starter out and bench test it with a pair of jumper cables and a battery, but you need to have it in a vice or lay it on the ground under a tire, like you're chocking it to keep it from rolling, the negative goes to an ear of the starter and the positive you just touch to the nut on the positive terminal. You just want to see if it's kicking out all the way. While the starter is out, you can inspect the teeth on the flexplate. You'll need to get a breakover on the crank nut and rotate the engine over by hand to inspect it all.
If you end up needing a new flexplate, let me know. I bought one from Ford a few years back for my '65 coupe as I was going to convert over to a C4, but ended up not doing it. I think all I ever did was bolt it up to the crank and mount the converter, come to think of it, I also have a new converter with some fluid in it. It's sealed, but I've lost the boxes to both of them. It's just stock stuff, the converter is a rebuilt one from a local company, I think the stock stall is like 1800.
haven't changed anything. it got worse only yesterday. didn't have that problem of the starter "whirrrin'" before. i did though have problems with starting the car before, but not the same way. the problem before was the engine would crank, but would not start. it had to do with the carb flooding or maybe a heat soaked starter. that problem stopped. i'll take off the starter after work and take to a parts store for testing. thanx everyone for the help.
took the starter out and took it to NAPA. it was bad, the gear inside was moving freely, which is not normal. so i replaced it with one of their remanufactured starter w/ limited lifetime warranty. tried installing it, but the rim does not fit the hole due to the powdercoat. so, i'm thinking of returning it and getting a PowerMaster XS Torque P/N 9504. what does everyone think? or should i just grind off the powdercoat?
The nose cone is powdercoated? It should just be bare aluminum, although some places paint the aluminum silver. Or are you talking about the powdercoat on your scattershield? I don't know that I'd mess with the Powermaster.
Did you make sure that the nosecone was 'clocked' the same as your old one? I bought a rebuilt starter and they had two different 'clockings' and neither was right for my Lakewood scattershield, so I swapped nosecones there on the counter. I then took the nosecone to a local starter shop and had them put a new bushing in it.
no, not the nose cone. i'm talking 'bout the circle that protrudes out ~1/4" from the base of the starter. or maybe the starter wasn't clocked right, but i just returned it and ordered the powermaster xs torque (my conscious feels better w/ a performance product). it should be coming in WED/THU.
After you put the car up on 4 jack stands all the way up:
1. Remove lower cover on the front of the tranny.
2. Remove the 4 nuts holding the converter to the flexplate.
3. Remove the tranny lines. If they're rubber, put a bolt inside the end and clamp off, if they're steel, put some plastic over the ends and rubber bands to hold it. This is just to keep all the fluid from running all over the floor out of your cooler.
4. Remove the starter from the bellhousing, I'd take the cable off as well.
5. Remove the straps off the rear u-joint and drop the rear of the shaft out of the way of the third member and pull it backwards until it's out of the back of the tranny. I like to tape some tape and wrap it around the rear u-joint to keep the free caps on. You might want to take the caps off carefully and look inside the cap and on the end of the joint to see it's condition. If it's got a zert, it'll be greasable, but if it doesn't, the only way to grease them it to disassemble them. Be very carefull not to loose the needle bearings.
6. If you don't have a rear tranny plug or an old yoke, wrap a piece of plastic around the end and zip tie it, then wrap a rag or two around the end and zip tie it as well. Remove the nuts holding the tranny to the crossmember and the nuts on the bolts holding the crossmember to the body. I like to take a small square of plywood and put it on top of my floor jack and put this under the front tranny pan, now you can remove the bolts holding the crossmember in and the crossmember. Remove the bolts holding the tranny on to the engine, most v8's have 6 although early ones had 5, I'm not sure how many I6's have, I think it's 5. Carefully slide the tranny back on the plywood making sure that the converter comes with the tranny and doesn't stay stuck on the flexplate, this way you don't have to get it set back into the front pump and won't loose any fluid. You should be able to lower the tranny now.
7. Remove the bolts holding the flexplate on and remove.
8. Put new flexplate on, there's only one way it can go on as one of the bolt holes is slightly off, so make sure they all hand start before tightening them all down. The holes for the converter should line up. Note, some converters have a drain plug installed and the new flexplate should have a corrosponding hole for the plug to go thru.
9. The rest is pretty much a reversal of taking it apart.
This is a good time to drain the fluid from the tranny, converter and cooler to replace it, also you'll need to remove the pan and replace the filter in the pan, but you don't have to do this step. Conventional wisdom has held that if you do regular fluid changes on any tranny, do it religiously, but if you neglect it, don't start doing it as stuff usually comes loose and plugs up the valve body, it doesn't take much, plus then they tend to leak, but most people have held that a C4 tends to be a leaker anyway.
