Starter Replacement
shlby123
579
Dallas
Hey everybody! Have a new 5.0 to work on! First time owning an '87 and Im not sure what, if any, the differences are between it and 89 & 93 models I've owned. Anywho, It's an '87 LX Droptop 5.0...with a 5 speed...and all power options... THAT ACTUALLY WORK! The top is rough, and the body is a bit as well, bit overall I feel great since it only cost $500!
Here's the deal though: The old owner said the starter just crapped out. Well that's an area I've never messed with before and I didnt know if there were any walkthroughs or maybe pictures of the exact area Im going to need to be working in order to replace the starter.
Another thing is, is that he said the vacuum lines are shot on it, Under the hood it doesnt look like much has been touched so, I can only assume that's true, any tips on this?
Oh! And he says the car has a surge idle problem. Can anybody at all point me in the right direction for solving this problem? I would so appreciate any tidbits of help on this beast and cant wait to be able to post up pics!
I'd get a late model stang starter. They dont sound like a piece of crap and are a little smaller.
Grab a nice selection of vac lines from the parts store and start replacing the vac lines. Two diagrams that might be helpful:
One
Two.
And see JRichker's idle surge sticky in the Technical thread Sticky at the top of the forum page.
Enjoy the new project!
kickasss that's an awesome start for me!!
On the starter real quick though, Are there any modifications that I need to make in order to put a later model stang starter on the car?
very simple......get a replacement starter...drive the car onto a set of ramps at the rear of the motor bolted to the bellhousing on the passenger side is where the starter is located....find it...ok first disconnect the negative battery cable remove the 2 bolts holding the starter to the bellhousing pull the starter down where you can remove the wires connected to the starter and label as you remove them for reinstall on new starter install new starter in reverse of removal....no mods necessary....
you have speed density right....the price depends on the owner of the donor car i would think you could get all the parts for about $200 - $300 (see approx price list below) click on link below for instructions on how to do it....
http://www.stangnet.com/tech/maf/massairconversion.html
Part Required Donor/Source Est. Price
EEC-IV Computer (mass air) 88-93 Mustang 5.0L(e.g. A9L, A9M, A3M) $125
Mass Air Sensor & Meter 88-93 Mustang 5.0L $50
Narrow Band Heated Oxygen Sensors 88-93 Mustang 5.0L $25 used about $120 new
18mm Oxygen Sensor Bung Summit G-2990 $5
Throttle body to mass air meter "Y" duct F5TZ-9B659-F-or-fabricate $?
what does it cost to convert to mass air?
there are many ways to conver to mass air.
1. There is a direct replacement kit that Ford Racing Sells
Summit Part # FMS-M-9000-A51 Manual
Summit Part # FMS-M-9000-B50
2. Take the nessecary wiring, MAF, etc from the junkyard
3. Or go aftermarket.
I went with the aftermarket converison using a C & L 76 mm MAF and 24 lbs injectors.
Check your mail box I sent you a pm.
If your new starter has a solenoid on its back, then you do a slight rewire of the starter circuit (it involves you needing to add one physically-small gauge wire from the oem solenoid to the new one). Ford thought this was a good idea and was using the newer 'mini' style starters by later in the aero fox run (a starter for a '93 should be a safe bet).
Good luck.
man, I dont know what I would do without this website. I dont believe there's a car out there on the road that carries a website dedicated to it as much as this one. :) Thanks everyone!
I have been staring at printouts of those electrical diagrams for a couple hours and it's pretty greek to me unfortunately.:(
How long (time wise) should it take to replace a bulk of the vacuum lines in this car?
What diagrams and what parts are a struggle? For a mini starter, you swap the big fat starter cable to the battery side of the solenoid. Then run a wire from where that cable used to attach, down to the S-terminal on the new starter's piggyback solenoid.
For vac lines, unless I have reason to think that the old ones are misrouted, I remove a line, cut a new line to the same length and replace it. Simple as that. As for how long it'd take, I'm unsure - I generally replace one batch at a time as they degrade.
Good luck.
Or head over to moates.net and get a J3 tuner board and programmer from Craig. Right after that, go over to diyautotune.com and get an Innovate wideband from Jerry. BAM! Lumpy cams and speed density getting along just fine. :nice:
Alright, so it isn't that easy, but it is an alternative to a mass air conversion for those who like tinkering with EFI like me. :D
Regarding a starter, I put a junky Autozone rebuilt in my '89 GT and it worked fine for about 20k until I sold the car. The one before that was original and had about 180,000 on it. A latemodel ministarter would have been nice, but it's not necessary.
The vacuum lines I had the most trouble with are the hard plastic ones on the passenger side of the engine bay. They get brittle and shatter. I used 1/8" ID vaccum hose to patch mine back together. Lots of other hoses were getting dried out and hard, but no breaks or leaks.
Im embarrassed to say that I wouldnt even be able to tell you what hoses or lines under the hood were the actual vacuum lines & hoses. The extent of my working knowledge of the mustang, is limited to mostly interior work, some body work, and then I have changed a heater just once! That's why I was hoping to just see a pic or two of an example of what any of the hoses look like or where they are exactly located. Im a visual learner, sorta!
